[petsc-users] Nesting splits based on IS
Karin&NiKo
niko.karin at gmail.com
Tue Apr 27 01:51:05 CDT 2021
Dear PETSc Team,
I am coming back to you to get some clue on the (missing?) Fortran
interface to the DMShellSetCreateSubDM routine.
Nicolas
Le dim. 25 avr. 2021 à 18:20, Karin&NiKo <niko.karin at gmail.com> a écrit :
> Dear Petsc Team,
> I have begun to write a small test to illustrate the use of a DMShell in
> order to nest splits from the command line.
> I am writing it in Fortran because the targeted application is also in
> Fortran.
> => I am afraid that DMShellSetCreateSubDM lacks a Fortran interface.
> Am I wrong ? Can't the interface be generated by bfort ?
> Thanks,
> Nicolas
> Le lun. 19 avr. 2021 à 12:28, Matthew Knepley <knepley at gmail.com> a
> écrit :
>> On Sun, Apr 18, 2021 at 11:54 PM Barry Smith <bsmith at petsc.dev> wrote:
>>> Matt,
>>> I agree it can be done with DMs, but I am not convinced that is
>>> necessarily a superior way when one has to make DMSHELLS and mess around
>>> with their behavior.
>>> One way to look at PCFIELDSPLIT is that its basic splitting tool is
>>> IS and DM is a way of generating IS that can be used for PCFIELDSPLIT. In
>>> this approach PCFIELDSPLIT needs a bit more support for IS and nesting. To
>>> also help using multiple levels of DM.
>>> The other way is to view DM and subDM as the basic splitting tool for
>>> PCFIELDSPLIT but then one has to ask the question how does DM communicate
>>> its splits to PCFIELDSPLIT? I am too lazy to look at the code but
>>> presumably with IS, hence the approach above.
>>> In the traditional Unix software stack approach to code, each layer
>>> uses the simpler layer below to communicate; so DM uses IS to communicate
>>> to the layer below (the linear algebra and preconditioners). DM is a
>>> hugely complicated layer and making it communicate directly with the vector
>>> level is complex; I like having the IS level in between to simplify the
>>> software stack and programming model.
>>> PetscSection makes live more complicated since it is a bit disjoint
>>> from IS. I've never resolved in my mind what role PetscSection plays, is it
>>> a level above IS in the software stack that generates IS, does it sometimes
>>> "skip over" IS to directly talk to linear algebra?
>>> If you cannot make a cartoon picture of the software stack, with all
>>> the objects, then I think the software stack is not well designed or
>>> defined. I fear we cannot make such a cartoon currently.
>> DM _does_ communicate with PCFIELDSPLIT using IS. I agree with you that
>> IS is a good object for communication. In PETSc, IS is just a nice way to
>> pass a list of integers.
>> I don't think DM is hugely complicated. It does a few simple jobs. Here
>> it's job is to remember which field each dof belongs to. That is all we
>> have to worry about.
>> PetscSection semantically is a linear space with some structure. We
>> already know we want some structure like this, since we break all linear
>> spaces in PETSc into processes. Section allows you to break it down a
>> little finer into the pieces of the space for each "point", where you can
>> use a point to mark anything you want, like a process, cell, edge, another
>> dof, etc. Sections can make an IS when asked a question, such as "which
>> dofs lie in the closure of this cell", or "which dofs are in this field",
>> or "which dofs are owned by this process". I have written this in the
>> manual years ago.
>> Matt
>>> Barry
>>> On Apr 18, 2021, at 8:54 AM, Matthew Knepley <knepley at gmail.com> wrote:
>>> On Sat, Apr 17, 2021 at 6:13 PM Barry Smith <bsmith at petsc.dev> wrote:
>>>> So you would like to be able to create three IS in your code and
>>>> attach them with names to the PC. Then have -pc_fieldsplit_XXX_fields be
>>>> able to utilize the attached IS by name and use them to define the blocks.
>>>> This is all doable and could be added to PCFIELDSPLIT without too
>>>> much code, new code. The code would be largely like
>>>> PCFieldSplitSetRuntimeSplits_Private.
>>>> The recursive part may also be doable but I think your syntax below
>>>> is not exactly right. You would need something like
>>>> -fieldsplit_0_pc_type fieldsplit // split the first PC into a
>>>> fieldsplit
>>>> -fieldsplit_0_pc_fieldsplit_0_fields xxx
>>>> -fieldsplit_0_fieldsplit_0_pc_type jacobi
>>>> -fieldsplit_0_pc_fieldsplit_1_fields yyy
>>>> etc
>>>> this would split the first field into two fields and use jacobi on the
>>>> first field.
>>>> The problem is what to use for labelling the xxx and the yyy?
>>>> I think one could achieve this by having the PCFIELDPLIT attach to each
>>>> of its split PCs the appropriate modified IS with names attached to them.
>>>> There are two cases,
>>>> when building the split uses first all the entries from
>>>> fieldsplit_v_, then from fieldsplit_p_ then the new ISs it needs to attach
>>>> to the first split PC are two sets of integers the first from 0 to the
>>>> len(v)-1 and the second from len(v) to len(v)+len(p)-1.
>>>> when building the split it interlaces the indices from v and p
>>>> (interlacing only make sense if the size of v and p is the same). Then the
>>>> new v would be {0,2,4,...} and p would be {1,3,...}.
>>>> If you are ambitious and would like to add this to fieldsplit.c we'd
>>>> be very happy to receive an MR. It might even lead to allowing us to simply
>>>> how the PCFIELDPLIT interacts with DMs. If all the split type, stride,
>>>> named, etc are handle in a single consistent manner.
>>> Barry, this is already working with DMs, which I think is the right way
>>> to do this.
>>> Here is the code:
>>> https://gitlab.com/petsc/petsc/-/blob/main/src/ksp/pc/impls/fieldsplit/fieldsplit.c#L420
>>> The DM must respond to DMCreateSubDM(). The interface is that the call
>>> provides a list of fields [f_0, f_1, ...]
>>> and the DM returns an IS for that combination and a subdm for it. The
>>> subdm part is what allows you to do this
>>> recursively, since you make the same call on the subdm.
>>> If you use a PetscSection to keep track of the data layout, the code to
>>> do field selection is already done:
>>> https://gitlab.com/petsc/petsc/-/blob/main/src/dm/interface/dmi.c#L105
>>> which can just be called from the DMCreateSubDM() implementation.
>>> Thanks,
>>> Matt
>>>> Barry
>>>> > On Apr 17, 2021, at 11:53 AM, Karin&NiKo <niko.karin at gmail.com>
>>>> wrote:
>>>> > Dear PETSc users,
>>>> > I use the fieldsplit PC in an application where the splits are
>>>> programmatically defined by IS using PCFieldSplitSetIS. Then the user can
>>>> specify its own PC at runtime using PETSc options.
>>>> > My question : is it possible to define nested splits in this case as
>>>> it can be done with strided splits (see snes/examples/tutorials/ex19.c with
>>>> test suffix fieldsplit_4).
>>>> > In order to be perfectly clear : let's say I have a 3 fields problem
>>>> : velocity (v split), pressure (p split) and temperature (t split).
>>>> > What I would like to do is something like the following but it fails
>>>> > -ksp_type fgmres
>>>> > -pc_fieldsplit_type multiplicative
>>>> > -pc_type fieldsplit -pc_fieldsplit_0_fields fieldsplit_v_,
>>>> fieldsplit_p_ -pc_fieldsplit_1_fields fieldsplit_t_
>>>> > -prefix_push fieldsplit_0_
>>>> > -ksp_type fgmres
>>>> > -pc_fieldsplit_schur_factorization_type upper
>>>> > -pc_type fieldsplit
>>>> > -pc_fieldsplit_type schur
>>>> > -pc_fieldsplit_schur_precondition a11
>>>> > -prefix_pop
>>>> > -prefix_push fieldsplit_1_
>>>> > -ksp_type fgmres
>>>> > -pc_type jacobi
>>>> > -prefix_pop
>>>> > -prefix_push fieldsplit_v_
>>>> > -ksp_type fgmres
>>>> > -pc_type gamg
>>>> > -prefix_pop
>>>> > -prefix_push fieldsplit_p_
>>>> > -ksp_type fgmres
>>>> > -pc_type jacobi
>>>> > -prefix_pop
>>>> > I thank you for your help,
>>>> > Nicolas
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/
>>> <http://www.cse.buffalo.edu/~knepley/>
>> experiments lead.
>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210427/138ce9a7/attachment.html>
