[petsc-users] Can I assign different local number of row and column to the parallel matrix in different process?
王 杰 wangjieneu at hotmail.com
Fri Apr 23 21:29:38 CDT 2021
hello,
I use petsc 3.14.5 with OpenMPI 3.1.6 in Ubuntu 18.04.5.
I don't well understand the routine  MatCreateAIJ(MPI_Comm comm,PetscInt m, PetscInt n,PetscInt M,PetscInt N,PetscInt d_nz,PetscInt *d_nnz, PetscInt o_nz,PetscInt *o_nnz,Mat *A).
I have tow process. The total number of global index is 2188. The first one deal with the global index 0~1400 with ghost node 1401~1500 and 2001~2188. The second process deal with globla index 1400~2100 with ghost node 601~700 and 701~800. This is dynamiclly assigned by load balancer.
I want to assign the first 1400 rows to the first process and the remained 788 rows in the second process. Can I give different values to m and n in the routine MatCreateAIJ in different process?
Thanks.
       Wang Jie
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210424/7a7305be/attachment.html>
