[petsc-users] Extracting solution at a boundary in a DMPlex/PetscFV paradigm
Thibault Bridel-Bertomeu thibault.bridelbertomeu at gmail.com
Thu Apr 22 07:48:53 CDT 2021
Hi Matthew,
Thank you for your answer.
I indeed already have the boundary marked I believe through the call to
PetscDSAddBoundary. I will try to add the vertices with DMPlexLabelComplete
and see how it behaves, thanks !
I'll come back in a little while with a piece of code so it will become
clearer hopefully.
Cheers,
Thibault
Le jeu. 22 avr. 2021 à 14:42, Matthew Knepley <knepley at gmail.com> a écrit :
> On Thu, Apr 22, 2021 at 8:31 AM Thibault Bridel-Bertomeu <
> thibault.bridelbertomeu at gmail.com> wrote:
>> Dear all,
>> I am working with multi-D DMPlex's coupled with PetscFV and a TS to solve
>> hyperbolic systems of equations. To add boundaries, I use the
>> PetscDSAddBoundary as shown in some examples throughout the documentation.
>> I do CFD, meaning I often have an object around which I want to simulate
>> the flow. And I would like to know how some variables (pressure for
>> instance) behave at the wall (literally _at_ the wall, and not only in the
>> first fluid cell above the wall).
>> After going through the documentation and the PETSc source code, I think
>> the way to go is to use something like what ex23.c (of plex/tests) does :
>> mark boundary faces that match the _wall_ boundary condition, create a
>> submesh with them and somehow project the PetscFV/TS solution onto those
>> facets based on the order of the spatial discretization (like if it's order
>> 1 then just use the value in the first fluid cell above the boundary
>> condition, if it's order 2 use the gradient and the value to get something
>> at the facet, etc...).
>> But I cannot figure out two things :
>> 1/ how to mark the right boundary faces ? I tried using the
>> DMPlexMarkBoundaryFaces with (what I thought was) the ID of the wall
>> boundary condition (I mean, I DMView'd the DMPlex and I picked the right id
>> in the Face Sets group), but then when I use the label thus created with
>> DMPlexCreateSubmesh, it just returns ... nothing. The "submesh" is empty
>> when I DMView it.
> I need to understand the question better. It seems like you already have
> the boundary marked. You just use that FaceSets label. If you want the
> submesh, you really need
> to mark vertices in addition to faces. To do this, you make a copy of the
> label you want, and then call DMPlexLabelComplete() on it. Then you can use
> it to create a submesh.
>> 2/ how to project on the facets in a PetscFV paradigm ?
> I believe that DMPlexProject() will work right now for order 1 projection.
> For order 2 with FV, we will have to write some new code.
>   Thanks,
>      Matt
>> Thank you very much in advance for any advice/pointers you could give me !
>> Take care and have a good day,
>> Thibault
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210422/e7711293/attachment.html>
