[petsc-users] MatDestroy problem with multiple matrices and SUPERLU_DIST
Xiaoye S. Li
xsli at lbl.gov
Wed Apr 21 10:01:05 CDT 2021
When you have two matrices, I think you should create two separate
communicators, i.e., two superlu grids,
Sherry Li
On Wed, Apr 21, 2021 at 6:08 AM Deij-van Rijswijk, Menno <M.Deij at marin.nl>
wrote:
> Good afternoon,
> In our code we're using two matrices that are preconditioned using
> SUPERLU_dist. Upon freeing the second matrix with MatDestroy, the program
> segfaults with the following stacktrace (see below). This happens with
> PETSc versions 3.14.5 and 3.15.0, whereas version 3.11.2 does not have this
> problem. In the code src\mat\impls\aij\mpi\superlu_dist\superlu_dist.c I
> see that Petsc_Superlu_dist_keyval_Delete_Fn has been added between 3.11.2
> and 3.14.5, and the comment reads that it allows reusing the communicator
> when only a single matrix is used at the time. I'm wondering if using
> multiple matrices with SUPERLU_dist is problematic here?
> Note: this is happening on single process and on multiple MPI processes.
> Best regards,
> Menno Deij - van Rijswijk
> #0 0x000015554ffc7db4 in ompi_comm_free () from
> /home/mdeij/install-gnu/extLibs/lib/libmpi.so.40
> #1 0x0000155550021536 in PMPI_Comm_free () from
> #2 0x00001555534262ba in superlu_gridexit (grid=0x3689da0)
> at
> /home/mdeij/install-gnu/extLibs/Linux-x86_64-Intel/superlu_dist-6.3.0/SRC/superlu_grid.c:174
> #3 0x0000155553df094b in Petsc_Superlu_dist_keyval_Delete_Fn
> (comm=0x26a4e50, keyval=16, attr_val=0x3689d90,
> extra_state=0x0)
> at
> /home/mdeij/build-libs-gnu/superbuild/petsc/src/src/mat/impls/aij/mpi/superlu_dist/superlu_dist.c:97
> #4 0x000015554ffc145c in ompi_attr_delete_impl () from
> #5 0x000015554ffc3fdf in ompi_attr_delete_all () from
> #6 0x000015554ffc7ca7 in ompi_comm_free () from
> #7 0x0000155550021536 in PMPI_Comm_free () from
> #8 0x00001555538f31c5 in PetscCommDestroy (comm=0x29712e0)
> at
> /home/mdeij/build-libs-gnu/superbuild/petsc/src/src/sys/objects/tagm.c:217
> #9 0x00001555538f55ab in PetscHeaderDestroy_Private (h=0x29712a0)
> at
> /home/mdeij/build-libs-gnu/superbuild/petsc/src/src/sys/objects/inherit.c:121
> #10 0x0000155553b44626 in MatDestroy (A=0x26e1c98)
> at
> /home/mdeij/build-libs-gnu/superbuild/petsc/src/src/mat/interface/matrix.c:1310
> #11 0x0000155553b87a86 in matdestroy_ (x=0x26e1c98, ierr=0x7fffffffc9cc)
> dr. ir. Menno A. Deij-van Rijswijk | Researcher | Research & Development
> MARIN | T +31 317 49 35 06 | M.Deij at marin.nl | www.marin.nl
> [image: LinkedIn] <https://www.linkedin.com/company/marin> [image:
> YouTube] <http://www.youtube.com/marinmultimedia> [image: Twitter]
> <https://twitter.com/MARIN_nieuws> [image: Facebook]
> <https://www.facebook.com/marin.wageningen>
> MARIN news: IWSA Open letter release for shipping decarbonisation
> <https://www.marin.nl/news/iwsa-open-letter-release-for-shipping-decarbonisation>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210421/72c39cf4/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210421/72c39cf4/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210421/72c39cf4/attachment-0005.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210421/72c39cf4/attachment-0006.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210421/72c39cf4/attachment-0007.png>
