[petsc-users] Rather different matrix product results on multiple processes
Peder Jørgensgaard Olesen
pjool at mek.dtu.dk
Wed Apr 21 04:22:30 CDT 2021
Dear Hong
Thank your for your reply.
I have a hunch that the issue goes beyond the minor differences that might arise from floating-point computation order, however.
Writing the product matrix to a binary file using MatView() and inspecting the output shows very different entries depending on the number of processes. Here are the first three rows and columns of the product matrix obtained in a sequential run:
2.58348 1.68202 1.66302
1.68202 4.27506 1.91897
1.66302 1.91897 2.70028
- and the corresponding part of the product matrix obtained on one node (40 processes):
4.43536 2.17261 0.16430
2.17261 4.53224 2.53210
0.16430 2.53210 4.73234
The parallel result is not even close to the sequential one. Trying different numbers of processes produces yet different results.
Also, the eigenvectors that I subsequently determine using a SLEPC solver do not form a proper basis for the column space of the data matrix as they must, which is hardly a surprise given the variability of results indicated above - except when the code is run on just a single process. Forming such a basis central to the intended application, and given that it would need to work on rather large data sets, running on a single process is hardly a viable solution.
Best regards
Peder
Fra: Zhang, Hong <hzhang at mcs.anl.gov>
Sendt: 19. april 2021 18:34:31
Til: petsc-users at mcs.anl.gov; Peder Jørgensgaard Olesen
Emne: Re: Rather different matrix product results on multiple processes
Peder,
I tested your code on a linux machine. I got
$ ./acorr_mwe
Data matrix norm: 5.0538e+01
Autocorrelation matrix norm: 1.0473e+03
mpiexec -n 40 ./acorr_mwe -matmattransmult_mpidense_mpidense_via allgatherv (default)
Autocorrelation matrix norm: 1.0363e+03
mpiexec -n 20 ./acorr_mwe
Autocorrelation matrix norm: 1.0897e+03
mpiexec -n 40 ./acorr_mwe -matmattransmult_mpidense_mpidense_via cyclic
I use petsc 'main' branch (same as the latest release). You can remove MatAssemblyBegin/End calls after MatMatTransposeMult():
MatMatTransposeMult(data_mat, data_mat, MAT_INITIAL_MATRIX, PETSC_DEFAULT, &corr_mat);
//ierr = MatAssemblyBegin(corr_mat, MAT_FINAL_ASSEMBLY); CHKERRQ(ierr);
//ierr = MatAssemblyEnd(corr_mat, MAT_FINAL_ASSEMBLY); CHKERRQ(ierr);
The communication patterns of parallel implementation led to different order of floating-point computation, thus slightly different matrix norm of R.
Hong
From: petsc-users <petsc-users-bounces at mcs.anl.gov> on behalf of Peder Jørgensgaard Olesen via petsc-users <petsc-users at mcs.anl.gov>
Sent: Monday, April 19, 2021 7:57 AM
To: petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
Subject: [petsc-users] Rather different matrix product results on multiple processes
Hello,
When computing a matrix product of the type R = D.DT using MatMatTransposeMult() I find I get rather different results depending on the number of processes. In one example using a data set that is small compared to the application I get Frobenius norms |R| = 1.047e3 on a single process, 1.0363e3 on a single HPC node (40 cores), and 9.7307e2 on two nodes.
I have ascertained that the single process result is indeed the correct one (i.e., eigenvectors of R form a proper basis for the columns of D), so naturally I'd love to be able to reproduce this result across different parallel setups. How might I achieve this?
I'm attaching MWE code and the data set used for the example.
Thanks in advance!
Best Regards
PhD Student, Turbulence Research Lab
Dept. of Mechanical Engineering
Technical University of Denmark
Niels Koppels Allé
Bygning 403, Rum 105
DK-2800 Kgs. Lyngby
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210421/49e65ab9/attachment-0001.html>
