[petsc-users] Rather different matrix product results on multiple processes
Peder Jørgensgaard Olesen
pjool at mek.dtu.dk
Mon Apr 19 07:57:44 CDT 2021
Hello,
When computing a matrix product of the type R = D.DT using MatMatTransposeMult() I find I get rather different results depending on the number of processes. In one example using a data set that is small compared to the application I get Frobenius norms |R| = 1.047e3 on a single process, 1.0363e3 on a single HPC node (40 cores), and 9.7307e2 on two nodes.
I have ascertained that the single process result is indeed the correct one (i.e., eigenvectors of R form a proper basis for the columns of D), so naturally I'd love to be able to reproduce this result across different parallel setups. How might I achieve this?
I'm attaching MWE code and the data set used for the example.
Thanks in advance!
Best Regards
PhD Student, Turbulence Research Lab
Dept. of Mechanical Engineering
Technical University of Denmark
Niels Koppels Allé
Bygning 403, Rum 105
DK-2800 Kgs. Lyngby
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210419/3f09853f/attachment-0001.html>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210419/3f09853f/attachment-0001.c>
Desc: sample_data.h5
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210419/3f09853f/attachment-0001.obj>
