[petsc-users] Can't compile code after upgrading to VS2017 and Intel One API + PETSc 3.15
TAY wee-beng
zonexo at gmail.com
Wed Apr 14 02:20:39 CDT 2021
Hi Mark,
I'm not sure what's wrong.
In VS2017 + Intel oneAPI,
even after adding the full path:
#include
<D:/Lib/petsc-3.15.0_win64_impi_vs2017/include/petsc/finclude/petscksp.h>
I got a new error:
/*Compiling with Intel® Fortran Compiler Classic 2021.2.0 [Intel(R)
64]...*//*
*//*ex2f.F90*//*
*//*petscksp.h(8): #error: can't find include file:
petsc/finclude/petscpc.h*//*
*//*ex2f : error PRJ0019: A tool returned an error code*/
Note that I have also specified the include dir in the properties:
/*Debug/;$(PETSC_DIR);$(PETSC_DIR)/include;$(I_MPI_ONEAPI_ROOT)/include*/
I also tried in cygwin:
/*export PETSC_DIR=`pwd`*//*
*//*export PETSC_ARCH=petsc-3.15.0_win64_impi_vs2017*//*
*//*make ex2f*/
I got the error:
/*$ make ex2f*//*
*//*makefile:41:
/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017/share/petsc/examples/src/ksp/ksp/tutorials/lib/petsc/conf/te*//*st:
No such file or directory*//*
*//*make: *** No rule to make target
'/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017/share/petsc/examples/src/ksp/ksp/tutori*//*als/lib/petsc/conf/test'.
Stop.*/
Somehow it just doesn't work. Building the library has no problem though.
I wonder what's wrong.
Thank you very much.
Yours sincerely,
TAY Wee-Beng 郑伟明 (Zheng Weiming)
Personal research webpage: _http://tayweebeng.wixsite.com/website_
Youtube research showcase: _https://goo.gl/PtvdwQ_
linkedin: _https://www.linkedin.com/in/tay-weebeng_
On 14/4/2021 9:31 am, Mark Adams wrote:
> PETSc has changed Fortran syntax since v3.9. You should upgrade. Look
> at examples for how to use modules etc.
> [Intel(R) 64]...*//*
> *//*global.F90*//*
> *//*global.F90(3): #error: can't find include file:
> petsc/finclude/petsc.h*//*
> *//*global.F90(937): #error: can't find include file:
> It looks like you might not have your PETSC_ARCH variable set. You
> should get a full path to /finclude/petsc.h. Look at the compile line.
> There are PETSc examples that you you can make to see an example of a
> correct make. For example,
> > cd petsc/src/ksp/ksp/tutorials
> > make ex2f
> should make an executable and you can look at the compile and link
> lines, and compare to what you are using.
> Mark
> Yours sincerely,
> <http://tayweebeng.wixsite.com/website>_
> <https://goo.gl/PtvdwQ>_
> <https://www.linkedin.com/in/tay-weebeng>_
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210414/837c2c84/attachment.html>
