[petsc-users] GAMG preconditioning
    Milan Pelletier
    milan.pelletier at protonmail.com
    Mon Apr 12 10:34:23 CDT 2021
Dear all,
I am currently trying to use PETSc with CG solver and GAMG preconditioner.
I have started with the following set of parameters:
-ksp_type cg
-pc_type gamg
-pc_gamg_agg_nsmooths 1
-pc_gamg_threshold 0.02
-mg_levels_ksp_type chebyshev
-mg_levels_pc_type sor
-mg_levels_ksp_max_it 2
Unfortunately, the preconditioning seems to run extremely slowly. I tried to play around with the numbers, to check if I could notice some difference, but could not observe significant changes.
As a comparison, the KSPSetup call with GAMG PC takes more than 10 times longer than completing the whole computation (preconditioning + ~400 KSP iterations to convergence) of the similar case using the following parameters :
-ksp_type cg
-pc_type ilu
-pc_factor_levels 0
The matrix size for my case is ~1,850,000*1,850,000 elements, with ~38,000,000 non-zero terms (i.e. ~20 per row). For both ILU and AMG cases I use matseqaij/vecseq storage (as a first step I work with only 1 MPI process).
Is there something wrong in the parameter set I have been using?
I understand that the preconditioning overhead with AMG is higher than with ILU, but I would also expect CG/GAMG to be competitive against CG/ILU, especially considering the relatively big problem size.
For information, I am using the PETSc version built from commit 6840fe907c1a3d26068082d180636158471d79a2 (release branch from April 7, 2021).
Any clue or idea would be greatly appreciated!
Thanks for your help,
Best regards,
Milan Pelletier
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210412/11a208f9/attachment.html>
