[petsc-users] Newbie question: Strange failure when calling PetscIntView from slepc application
Barry Smith
bsmith at petsc.dev
Sat Apr 10 18:51:11 CDT 2021
I have submitted a MR that adds a Fortran interface for these functions so it will automatically error at compile time if you do not include the appropriate arguments.
Barry
> On Apr 9, 2021, at 5:35 AM, dazza simplythebest <sayosale at hotmail.com> wrote:
> Dear Pierre and Stefano,
> Yes - that is it! I had just stumbled onto that
> point as your email arrived thanks to Stefano's guidance, which suggested the problem was that the routine
> was receiving an integer when it was expecting something else... then a lightbulb
> finally switched on and I finally remembered that I needed to add the error variable
> as a final argument. I thought it was something silly on my part, and I wasn't mistaken
> there at least!
> Many thanks to both of you,
> best wishes,
> Dan.
> From: Pierre Seize <pierre.seize at onera.fr <mailto:pierre.seize at onera.fr>>
> Sent: Friday, April 9, 2021 10:14 AM
> To: Stefano Zampini <stefano.zampini at gmail.com <mailto:stefano.zampini at gmail.com>>; dazza simplythebest <sayosale at hotmail.com <mailto:sayosale at hotmail.com>>
> Cc: petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov> <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>>
> Subject: Re: [petsc-users] Newbie question: Strange failure when calling PetscIntView from slepc application
> Hello, I think you forgot to pass ierr as the last argument of PetscIntView.
> Pierre
> On 09/04/21 11:52, Stefano Zampini wrote:
>> ==841883== Invalid write of size 4
>> ==841883== at 0x503E784: petscintview_ (/data/work/slepc/PETSC/petsc-3.14.5/src/sys/error/ftn-custom/zerrf.c:109)
>> ==841883== by 0x40262C: all_stab_routines_mp_write_rows_to_petsc_matrix_ (/data/work/rotplane/omega_to_zero/stability/test/tmp10/tmp3/tryme.F:17)
>> ==841883== by 0x402465: MAIN__ (/data/work/rotplane/omega_to_zero/stability/test/tmp10/tmp3/tryme.F:40)
>> ==841883== by 0x402221: main (in /data/work/rotplane/omega_to_zero/stability/test/tmp10/tmp3/trashy.exe)
>> ==841883== Address 0x0 is not stack'd, malloc'd or (recently) free'd
>> ==841883==
>> This exactly points to the error and suggests you to take a look at /data/work/slepc/PETSC/petsc-3.14.5/src/sys/error/ftn-custom/zerrf.c, line 109
>> You are trying to write 4 bytes (most probably an int) where is not allowed.
>>> On Apr 9, 2021, at 12:32 PM, dazza simplythebest <sayosale at hotmail.com <mailto:sayosale at hotmail.com>> wrote:
>>> ==841883==
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210410/02cb879f/attachment.html>
