[petsc-users] Undefined reference in PETSc 3.13+ with old MPI version
Junchao Zhang junchao.zhang at gmail.com
Sat Apr 10 16:36:44 CDT 2021
Hi, Danyang,
Send the configure.log.  Also, PETSc does not need MPI_Win_allocate etc to
work. I will have a look.
--Junchao Zhang
On Sat, Apr 10, 2021 at 2:47 PM Danyang Su <danyang.su at gmail.com> wrote:
> Hi Barry,
> I tried this option before but get ‘Error running configure on OpenMPI’
>          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for
> details):
> Error running configure on OPENMPI
>   File
> "/global/home/danyangs/soft/petsc/petsc-3.14.6/config/configure.py", line
> 456, in petsc_configure
>     framework.configure(out = sys.stdout)
>   File
> "/global/home/danyangs/soft/petsc/petsc-3.14.6/config/BuildSystem/config/framework.py",
> line 1253, in configure
>     self.processChildren()
>   File
> line 1242, in processChildren
>     self.serialEvaluation(self.childGraph)
>   File
> line 1217, in serialEvaluation
>     child.configure()
>   File
> "/global/home/danyangs/soft/petsc/petsc-3.14.6/config/BuildSystem/config/package.py",
> line 1144, in configure
>     self.executeTest(self.configureLibrary)
>   File
> "/global/home/danyangs/soft/petsc/petsc-3.14.6/config/BuildSystem/config/base.py",
> line 140, in executeTest
>     ret = test(*args,**kargs)
>   File
> line 902, in configureLibrary
>     for location, directory, lib, incl in self.generateGuesses():
>   File
> line 476, in generateGuesses
>     d = self.checkDownload()
>   File
> "/global/home/danyangs/soft/petsc/petsc-3.14.6/config/BuildSystem/config/packages/OpenMPI.py",
> line 56, in checkDownload
>     return self.getInstallDir()
>   File
> line 365, in getInstallDir
>     installDir = self.Install()
>   File
> line 63, in Install
>     installDir = config.package.GNUPackage.Install(self)
>   File
> line 1667, in Install
>     raise RuntimeError('Error running configure on ' + self.PACKAGE)
> Finishing configure run at Sat, 10 Apr 2021 11:57:20 -0700
> Thanks,
> Danyang
> *From: *Barry Smith <bsmith at petsc.dev>
> *Date: *Saturday, April 10, 2021 at 10:31 AM
> *To: *Danyang Su <danyang.su at gmail.com>
> *Cc: *"petsc-users at mcs.anl.gov" <petsc-users at mcs.anl.gov>
> *Subject: *Re: [petsc-users] Undefined reference in PETSc 3.13+ with old
> MPI version
>   Depending on the network you can remove the ./configure
> options --with-cc=mpicc --with-cxx=mpicxx --with-fc=mpif90  and use instead
> --with-cc=icc --with-cxx=icpc and--with-fc=ifort --download-openmpi
>   Barry
> On Apr 10, 2021, at 12:18 PM, Danyang Su <danyang.su at gmail.com> wrote:
> Dear PETSc developers and users,
> I am trying to install the latest PETSc version on an ancient cluster. The
> OpenMPI version is 1.6.5 and Compiler is Intel 14.0, which are the newest
> on that cluster. I have no problem to install PETSc up to version 3.12.5.
> However, if I try to use PETSc 3.13+, there are three undefined reference
> errors in MPI_Win_allocate, MPI_Win_attach and MPI_Win_create_dynamic. I
> know these three functions are available from OpenMPI 2.0+. Because the
> cluster is not in technical support anymore, there is no way I can install
> new OpenMPI version or do some update. Is it possible to disable these
> three functions in PETSc 3.13+ version?
> The errors occur in ‘make check’ step:
> /home/dsu/soft/petsc/petsc-3.13.0/linux-intel-openmpi/lib/libpetsc.so:
> undefined reference to `MPI_Win_allocate'
> undefined reference to `MPI_Win_attach'
> undefined reference to `MPI_Win_create_dynamic'
> The configuration used is shown below:
> ./configure --with-cc=mpicc --with-cxx=mpicxx --with-fc=mpif90
> --download-mumps --download-scalapack --download-parmetis --download-metis
> --download-fblaslapack --download-hypre --download-superlu
> --download-hdf5=yes --with-debugging=0 COPTFLAGS="-O3 -march=native
> -mtune=native" CXXOPTFLAGS="-O3 -march=native -mtune=native" FOPTFLAGS="-O3
> -march=native -mtune=nativels"
> Thanks,
> Danyang
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210410/96c21c3a/attachment.html>
