[petsc-users] Newbie question: Strange failure when calling PetscIntView from slepc application
Pierre Seize
pierre.seize at onera.fr
Fri Apr 9 05:14:46 CDT 2021
Hello, I think you forgot to pass ierr as the last argument of PetscIntView.
Pierre
On 09/04/21 11:52, Stefano Zampini wrote:
> ==841883== Invalid write of size 4
> ==841883== at 0x503E784: petscintview_
> (/data/work/slepc/PETSC/petsc-3.14.5/src/sys/error/ftn-custom/zerrf.c:109)
> ==841883== by 0x40262C:
> all_stab_routines_mp_write_rows_to_petsc_matrix_
> (/data/work/rotplane/omega_to_zero/stability/test/tmp10/tmp3/tryme.F:17)
> ==841883== by 0x402465: MAIN__
> (/data/work/rotplane/omega_to_zero/stability/test/tmp10/tmp3/tryme.F:40)
> ==841883== by 0x402221: main (in
> /data/work/rotplane/omega_to_zero/stability/test/tmp10/tmp3/trashy.exe)
> ==841883== Address 0x0 is not stack'd, malloc'd or (recently) free'd
> ==841883==
> This exactly points to the error and suggests you to take a look at
> /data/work/slepc/PETSC/petsc-3.14.5/src/sys/error/ftn-custom/zerrf.c,
> line 109
> You are trying to write 4 bytes (most probably an int) where is not
> allowed.
>> On Apr 9, 2021, at 12:32 PM, dazza simplythebest
>> ==841883==
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210409/98465548/attachment.html>
