[petsc-users] VecLoad from HDF5 file
Thibault Bridel-Bertomeu thibault.bridelbertomeu at gmail.com
Thu Apr 8 06:35:52 CDT 2021
Argh no I don't, I implemented it straight in a larger CFD code because
everything is already there for setting-up the DM, DS, PetscFV etc...
Now that you guys gave me some more pointers I'll dig around with a
debugger ..
Thanks !
Le jeu. 8 avr. 2021 à 13:25, Matthew Knepley <knepley at gmail.com> a écrit :
> Do you have a self-contained thing I could run? This should be easy to
> clear up in the debugger.
>   Thanks,
>      Matt
> On Thu, Apr 8, 2021 at 7:22 AM Thibault Bridel-Bertomeu <
> thibault.bridelbertomeu at gmail.com> wrote:
>> Doesn't seem to be a Fortran stub problem, it's automatically generated
>> and looks good to me ...
>> Le jeu. 8 avr. 2021 à 13:20, Thibault Bridel-Bertomeu <
>> thibault.bridelbertomeu at gmail.com> a écrit :
>>> Well ... I cleaned everything and did a fresh compile just now with
>>> "print*, "foo"" here and there and it does print foo on the terminal  ...
>>> So yes, I am running the changed code ! ;)
>>> call DMCreateGlobalVector(dm, sol, ierr); CHKERRA(ierr)
>>> call VecZeroEntries(sol, ierr); CHKERRA(ierr)
>>> call PetscObjectSetName(sol, "Solution", ierr); CHKERRA(ierr)
>>> print*, "foo"
>>> call PetscViewerCreate(PETSC_COMM_WORLD, hdf5Viewer, ierr);
>>> CHKERRA(ierr)
>>> call PetscViewerSetType(hdf5Viewer, PETSCVIEWERHDF5, ierr);
>>> CHKERRA(ierr)
>>> call PetscViewerFileSetMode(hdf5Viewer, FILE_MODE_READ, ierr);
>>> CHKERRA(ierr)
>>> call PetscViewerFileSetName(hdf5Viewer, trim(restartname), ierr);
>>> CHKERRA(ierr)
>>> call PetscViewerHDF5SetTimestep(hdf5Viewer, restartiter, ierr);
>>> CHKERRA(ierr)
>>> call PetscViewerHDF5PushGroup(hdf5Viewer, "/fields", ierr);
>>> CHKERRA(ierr)
>>> call VecLoad(sol, hdf5Viewer, ierr); CHKERRA(ierr)
>>> call PetscViewerDestroy(hdf5Viewer, ierr); CHKERRA(ierr)
>>> In the snippet, restartiter is an integer equal to 20.
>>> I agree with you the line you just sent me should fix the issue. Maybe
>>> it's a fortran stub problem, I'll double check the stubs.
>>> Thanks !
>>> Thibault
>>> Le jeu. 8 avr. 2021 à 13:11, Matthew Knepley <knepley at gmail.com> a
>>> écrit :
>>>> On Thu, Apr 8, 2021 at 4:08 AM Thibault Bridel-Bertomeu <
>>>>> Hi everyone,
>>>>> Thank you for your answers.
>>>>> Unfortunately, it does not work yet.
>>>>> 1/ I first tried just adding
>>>>>  call PetscViewerHDF5SetTimestep(hdf5Viewer, 20, ierr); CHKERRA(ierr)
>>>>> (the latest iteration in the *.hdf5 is iter 20) before the VecLoad,
>>>>> i.e.:
>>>>> CHKERRA(ierr)
>>>>> CHKERRA(ierr)
>>>>> CHKERRA(ierr)
>>>>> CHKERRA(ierr)
>>>>> CHKERRA(ierr)
>>>>> but it does not change anything, the error is exactly the same as
>>>>> before (with or without the PushGroup by the way).
>>>> This is the one I do not believe. If the Viewer has a non-negative
>>>> timestep, it will increase the length index:
>>>> https://gitlab.com/petsc/petsc/-/blob/main/src/vec/is/utils/hdf5io.c#L78
>>>> and we can see all the sizes in your HDF5 file. Are you sure you are
>>>> running the one with the changed code?
>>>>   Thanks,
>>>>      Matt
>>>>> 2/ I then tried adding
>>>>>  call PetscViewerHDF5SetTimestep(hdf5Viewer, -1, ierr); CHKERRA(ierr)
>>>>> before the VecView to "prevent blocking with timesteps" as the doc
>>>>> says (
>>>>> https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Viewer/PetscViewerHDF5SetTimestep.html#PetscViewerHDF5SetTimestep),
>>>>> i.e. :
>>>>> CHKERRA(ierr)
>>>>> CHKERRA(ierr)
>>>>> call PetscViewerFileSetMode(hdf5Viewer, FILE_MODE_WRITE, ierr);
>>>>> CHKERRA(ierr);
>>>>> write(filename,'(A,I5.5,A)') "restart_", stepnum, ".h5"
>>>>> call PetscViewerFileSetName(hdf5Viewer, trim(filename), ierr);
>>>>> CHKERRA(ierr)
>>>>> call VecView(X, hdf5Viewer, ierr); CHKERRA(ierr)
>>>>> but the hdf5 files keep increasing in size and each one stores more
>>>>> data than the previous one ... can I not disable that "stacking" effect and
>>>>> just keep the iteration I want ?
>>>>> 3/ I tried adding
>>>>>  call PetscViewerHDF5SetTimestep(hdf5Viewer, stepnum, ierr);
>>>>> CHKERRA(ierr)
>>>>> before the VecView to try and just keep one iteration in the file,
>>>>> i.e. :
>>>>> CHKERRA(ierr)
>>>>> CHKERRA(ierr)
>>>>> CHKERRA(ierr);
>>>>> CHKERRA(ierr)
>>>>> CHKERRA(ierr)
>>>>> but it has no effect whatsoever on the hdf5 files that are written ...
>>>>> they still store several timesteps, and then I cannot VecLoad what I want,
>>>>> i still get the same error.
>>>>> Any more idea ? I keep reading the doc on the HDF5 viewer and thinking
>>>>> that this or that function could solve the issue but either it has zero
>>>>> effect or does not solve the issue ...
>>>>> Thanks !!!
>>>>> Thibault
>>>>> Le jeu. 8 avr. 2021 à 02:42, Barry Smith <bsmith at petsc.dev> a écrit :
>>>>>>    Matt,
>>>>>>    Is there anyway to provide this "extra meta-data" inside the
>>>>>> generated HDF file? Then when a fresh viewer opens the file it uses this
>>>>>> meta-data to know that the file contains "time-steps" and allows processing
>>>>>> of them? The simplest thing would be to have the viewer generate an error
>>>>>> if the file has time-steps but the user does not "request a (or more)
>>>>>> time-steps" instead of getting confused about the vector sizes.
>>>>>>   Barry
>>>>>> On Apr 7, 2021, at 6:32 PM, Matthew Knepley <knepley at gmail.com>
>>>>>> wrote:
>>>>>> On Wed, Apr 7, 2021 at 4:10 PM Thibault Bridel-Bertomeu <
>>>>>>> Hello Vaclav,
>>>>>>> Thank you for your quick answer !!
>>>>>>> OK so, if I need to push the group, I added :
>>>>>>> CHKERRA(ierr)
>>>>>>> right after the call to PetscViewerFileSetName.
>>>>>>> The result is the same, it produces the following error :
>>>>>>> *[0]PETSC ERROR: --------------------- Error Message
>>>>>>> [0]PETSC ERROR: Unexpected data in file
>>>>>>> [0]PETSC ERROR: Global size of array in file is 105, not 25300 as
>>>>>>> expected
>>>>>>> [0]PETSC ERROR: See
>>>>>>> https://www.mcs.anl.gov/petsc/documentation/faq.html for trouble
>>>>>>> shooting.
>>>>>>> [0]PETSC ERROR: Petsc Development GIT revision:
>>>>>>> v3.14.4-671-g707297fd510  GIT Date: 2021-02-24 22:50:05 +0000
>>>>>>> [0]PETSC ERROR: ../../../bin/eulerian3D on a  named
>>>>>>> macbook-pro-de-thibault.home by tbridel Wed Apr  7 22:05:14 2021
>>>>>>> [0]PETSC ERROR: Configure options --with-clean=1
>>>>>>> --prefix=/Users/tbridel/Documents/1-CODES/04-PETSC/build_uns3D
>>>>>>> --with-make-np=2 --with-windows-graphics=0 --with-debugging=0
>>>>>>> --download-fblaslapack --download-mpich-shared=0 --with-x=0
>>>>>>> --with-pthread=0 --with-valgrind=0 --PETSC_ARCH=macosx_uns3D
>>>>>>> --with-fc=/usr/local/bin/mpifort --with-cc=/usr/local/bin/mpicc
>>>>>>> --with-cxx=/usr/local/bin/mpic++ --with-openmp=0 --download-hypre=yes
>>>>>>> --download-sowing=yes --download-metis=yes --download-parmetis=yes
>>>>>>> --download-triangle=yes --download-tetgen=yes --download-ctetgen=yes
>>>>>>> --download-p4est=yes --download-zlib=yes --download-c2html=yes
>>>>>>> --download-eigen=yes --download-pragmatic=yes
>>>>>>> --with-hdf5-dir=/usr/local/opt/hdf5-mpi
>>>>>>> --with-cmake-dir=/usr/local/opt/cmake
>>>>>>> --with-libtoolize=/usr/local/bin/glibtoolize
>>>>>>> --with-autoreconf=/usr/local/bin/autoreconf
>>>>>>> [0]PETSC ERROR: #1 PetscViewerHDF5ReadSizes_Private() line 114 in
>>>>>>> /Users/tbridel/Documents/1-CODES/04-PETSC/src/vec/is/utils/hdf5io.c
>>>>>>> [0]PETSC ERROR: #2 PetscViewerHDF5Load() line 208 in
>>>>>>> [0]PETSC ERROR: #3 VecLoad_HDF5() line 132 in
>>>>>>> /Users/tbridel/Documents/1-CODES/04-PETSC/src/vec/vec/utils/vecio.c
>>>>>>> [0]PETSC ERROR: #4 VecLoad_Default() line 257 in
>>>>>>> [0]PETSC ERROR: #5 VecLoad_Plex_Local() line 474 in
>>>>>>> /Users/tbridel/Documents/1-CODES/04-PETSC/src/dm/impls/plex/plex.c
>>>>>>> [0]PETSC ERROR: #6 VecLoad_Plex_HDF5_Internal() line 295 in
>>>>>>> /Users/tbridel/Documents/1-CODES/04-PETSC/src/dm/impls/plex/plexhdf5.c
>>>>>>> [0]PETSC ERROR: #7 VecLoad_Plex() line 496 in
>>>>>>> [0]PETSC ERROR: #8 VecLoad() line 953 in
>>>>>>> /Users/tbridel/Documents/1-CODES/04-PETSC/src/vec/vec/interface/vector.c
>>>>>>> [0]PETSC ERROR: #9 User provided function() line 0 in User file
>>>>>>> Do you know where it could come from ?
>>>>>> I think I understand this. PETSc tries to be clever to allow you to
>>>>>> store timesteps. It gives the HDF5 array an extra dimension. Somehow
>>>>>> the Viewer has to know this. The TS does this automatically, so you
>>>>>> have an array
>>>>>>   GROUP "fields" {
>>>>>>       DATASET "Solution" {
>>>>>>          DATATYPE  H5T_IEEE_F64LE
>>>>>>          DATASPACE  SIMPLE { ( 21, 5060, 5 ) / ( H5S_UNLIMITED, 5060,
>>>>>> 5 ) }
>>>>>> which has 21 timesteps. However, when you create a brand new Viewer,
>>>>>> it does not know, and mistakenly thinks there is a single vector
>>>>>> of length 21 * 5 = 105. You can tell your reader which timestep you
>>>>>> want to extract using
>>>>>>   Thanks,
>>>>>>     Matt
>>>>>>> As for what I am doing exactly : i am using the DMPlex with a
>>>>>>> PetscFV to solve the fluid mechanics Euler equations in 3D. The PetscFV
>>>>>>> linked to the DS of the DMPlex might be why there is a /fields before the
>>>>>>> /Solution maybe .. ?
>>>>>>> Cheers and thank you again for your help !!
>>>>>>> Thibault
>>>>>>> Le mer. 7 avr. 2021 à 10:07, Hapla Vaclav <vaclav.hapla at erdw.ethz.ch>
>>>>>>> a écrit :
>>>>>>>> Dear Thibault
>>>>>>>> On 7 Apr 2021, at 08:18, Thibault Bridel-Bertomeu <
>>>>>>>> Dear all,
>>>>>>>> I have been facing a problem with VecLoad recently, even though it
>>>>>>>> seems to me I did exactly like in the examples/tutorials.
>>>>>>>> Basically, a program writes a vector with the HDF5 writer like this
>>>>>>>>                 call DMCreateGlobalVector(dm, sol, ierr);           CHKERRA(ierr)                call VecZeroEntries(X, ierr);                     CHKERRA(ierr)                call PetscObjectSetName(X, "Solution", ierr);     CHKERRA(ierr)
>>>>>>>>                 < do something with X to fill it up with relevant data >
>>>>>>>>                 call PetscViewerCreate(PETSC_COMM_WORLD, hdf5Viewer, ierr); CHKERRA(ierr)                call PetscViewerSetType(hdf5Viewer, PETSCVIEWERHDF5, ierr); CHKERRA(ierr)                call PetscViewerFileSetMode(hdf5Viewer, FILE_MODE_WRITE, ierr); CHKERRA(ierr);                write(filename,'(A,I5.5,A)') "restart_", stepnum, ".h5"                call PetscViewerFileSetName(hdf5Viewer, trim(filename), ierr); CHKERRA(ierr)                call VecView(X, hdf5Viewer, ierr); CHKERRA(ierr)                call PetscViewerDestroy(hdf5Viewer, ierr); CHKERRA(ierr)
>>>>>>>> and the same program (but with different start-up options, say)
>>>>>>>> re-reads such a file like this :
>>>>>>>>                 call DMCreateGlobalVector(dm, sol, ierr);           CHKERRA(ierr)                call VecZeroEntries(sol, ierr);                     CHKERRA(ierr)                call PetscObjectSetName(sol, "Solution", ierr);     CHKERRA(ierr)
>>>>>>>>                 call PetscViewerCreate(PETSC_COMM_WORLD, hdf5Viewer, ierr); CHKERRA(ierr)                call PetscViewerSetType(hdf5Viewer, PETSCVIEWERHDF5, ierr); CHKERRA(ierr)                call PetscViewerFileSetMode(hdf5Viewer, FILE_MODE_READ, ierr); CHKERRA(ierr)                call PetscViewerFileSetName(hdf5Viewer, trim(restartname), ierr); CHKERRA(ierr)                call VecLoad(sol, hdf5Viewer, ierr); CHKERRA(ierr)                call PetscViewerDestroy(hdf5Viewer, ierr); CHKERRA(ierr)
>>>>>>>> Such a dataset can be found under this link :
>>>>>>>> https://drive.google.com/file/d/1owLAx5vknNhj61_5ieAwnWOR9cmkTseL/view?usp=sharing
>>>>>>>> I'm just looking at the HDF5 file. The structure is like this
>>>>>>>> > $PETSC_DIR/$PETSC_ARCH/bin/h5dump -H restart_00020.h5
>>>>>>>> HDF5 "restart_00020.h5" {
>>>>>>>> GROUP "/" {
>>>>>>>>    GROUP "cell_fields" {
>>>>>>>>       DATASET "Solution_FV solver" {
>>>>>>>>          DATASPACE  SIMPLE { ( 21, 3884, 5 ) / ( H5S_UNLIMITED,
>>>>>>>> 3884, 5 ) }
>>>>>>>>          ATTRIBUTE "vector_field_type" {
>>>>>>>>             DATATYPE  H5T_STRING {
>>>>>>>>                STRSIZE 7;
>>>>>>>>                STRPAD H5T_STR_NULLTERM;
>>>>>>>>                CSET H5T_CSET_ASCII;
>>>>>>>>                CTYPE H5T_C_S1;
>>>>>>>>             DATASPACE  SCALAR
>>>>>>>>    GROUP "fields" {
>>>>>>>> 5060, 5 ) }
>>>>>>>>    DATASET "time" {
>>>>>>>>       DATASPACE  SIMPLE { ( 21, 1 ) / ( H5S_UNLIMITED, 1 ) }
>>>>>>>> I would like the reader to read the /fields/Solution group
>>>>>>>> basically, but I am not even sure it tries to do that.
>>>>>>>> Anyhow, I got an error, saying that the size found in the file
>>>>>>>> (105) does not match the expected size (25300). If I look at the shape of
>>>>>>>> /fields/Solution it is given as (21, 5030, 5). First, it is weird, cause
>>>>>>>> the 21 seems to be 1 + current iteration number ... but anyways we find the
>>>>>>>> 5 variables and the 5030 cells. Only the reader seems to do 21 * 5 when it
>>>>>>>> should be doing 5030 * 5 ...
>>>>>>>> I tried adding 'PetscViewerHDF5PushGroup(hdf5Viewer,
>>>>>>>> "/fields/Solution", ierr)' to force it to read that group, but it does not
>>>>>>>> change anything.
>>>>>>>> You definitely need to push the group, unless it's the root group
>>>>>>>> "/". There is no way the reader would guess the correct group if it's not
>>>>>>>> the root one [and I don't think it would be a good idea to implement such
>>>>>>>> searching].
>>>>>>>> If you tried adding
>>>>>>>>   PetscViewerHDF5PushGroup(hdf5Viewer, "/fields/Solution", ierr)
>>>>>>>> you likely pushed a wrong group. If the Vec name was set to
>>>>>>>> "Solution" like in your snippet [using PetscObjectSetName()], the absolute
>>>>>>>> dataset name to look up would be "/fields/Solution/Solution".
>>>>>>>> But in your file, there's just a dataset "/fields/Solution", so its
>>>>>>>> parent group is just "/fields". So please try pushing this.
>>>>>>>> I would gladly try to reproduce your case - perhaps the error
>>>>>>>> handling should be improved so that it would guide you into the right
>>>>>>>> direction. But it would be helpful to know exactly what you're doing - the
>>>>>>>> snippet with VecView() above should produce "/Solution" dataset but in the
>>>>>>>> file you're sending, there's "/fields/Solution".
>>>>>>>> Note also you don't need to do VecZeroEntries() before loading
>>>>>>>> because VecLoad() fully rewrites the Vec data in memory anyway.
>>>>>>>> I would appreciate it if anyone could give me pointers on this
>>>>>>>> issue ...
>>>>>>>> Thank you very much in advance !!
>>>>>>>> Thibault
>>>>>>>> Thanks,
>>>>>>>> Vaclav
>>>>>> What most experimenters take for granted before they begin their
>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>>> experiments lead.
>>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210408/703cf95f/attachment-0001.html>
