[petsc-users] VecLoad from HDF5 file
Barry Smith bsmith at petsc.dev
Wed Apr 7 19:42:46 CDT 2021
   Matt,
   Is there anyway to provide this "extra meta-data" inside the generated HDF file? Then when a fresh viewer opens the file it uses this meta-data to know that the file contains "time-steps" and allows processing of them? The simplest thing would be to have the viewer generate an error if the file has time-steps but the user does not "request a (or more) time-steps" instead of getting confused about the vector sizes.
  Barry
> On Apr 7, 2021, at 6:32 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Apr 7, 2021 at 4:10 PM Thibault Bridel-Bertomeu <thibault.bridelbertomeu at gmail.com <mailto:thibault.bridelbertomeu at gmail.com>> wrote:
> Hello Vaclav,
> Thank you for your quick answer !!
> OK so, if I need to push the group, I added :
> call PetscViewerHDF5PushGroup(hdf5Viewer, "/fields", ierr); CHKERRA(ierr)
> right after the call to PetscViewerFileSetName.
> The result is the same, it produces the following error :
> [0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> [0]PETSC ERROR: Unexpected data in file
> [0]PETSC ERROR: Global size of array in file is 105, not 25300 as expected
> [0]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html <https://www.mcs.anl.gov/petsc/documentation/faq.html> for trouble shooting.
> [0]PETSC ERROR: Petsc Development GIT revision: v3.14.4-671-g707297fd510  GIT Date: 2021-02-24 22:50:05 +0000
> [0]PETSC ERROR: ../../../bin/eulerian3D on a  named macbook-pro-de-thibault.home by tbridel Wed Apr  7 22:05:14 2021
> [0]PETSC ERROR: Configure options --with-clean=1 --prefix=/Users/tbridel/Documents/1-CODES/04-PETSC/build_uns3D --with-make-np=2 --with-windows-graphics=0 --with-debugging=0 --download-fblaslapack --download-mpich-shared=0 --with-x=0 --with-pthread=0 --with-valgrind=0 --PETSC_ARCH=macosx_uns3D --with-fc=/usr/local/bin/mpifort --with-cc=/usr/local/bin/mpicc --with-cxx=/usr/local/bin/mpic++ --with-openmp=0 --download-hypre=yes --download-sowing=yes --download-metis=yes --download-parmetis=yes --download-triangle=yes --download-tetgen=yes --download-ctetgen=yes --download-p4est=yes --download-zlib=yes --download-c2html=yes --download-eigen=yes --download-pragmatic=yes --with-hdf5-dir=/usr/local/opt/hdf5-mpi --with-cmake-dir=/usr/local/opt/cmake --with-libtoolize=/usr/local/bin/glibtoolize --with-autoreconf=/usr/local/bin/autoreconf
> [0]PETSC ERROR: #1 PetscViewerHDF5ReadSizes_Private() line 114 in /Users/tbridel/Documents/1-CODES/04-PETSC/src/vec/is/utils/hdf5io.c
> [0]PETSC ERROR: #2 PetscViewerHDF5Load() line 208 in /Users/tbridel/Documents/1-CODES/04-PETSC/src/vec/is/utils/hdf5io.c
> [0]PETSC ERROR: #3 VecLoad_HDF5() line 132 in /Users/tbridel/Documents/1-CODES/04-PETSC/src/vec/vec/utils/vecio.c
> [0]PETSC ERROR: #4 VecLoad_Default() line 257 in /Users/tbridel/Documents/1-CODES/04-PETSC/src/vec/vec/utils/vecio.c
> [0]PETSC ERROR: #5 VecLoad_Plex_Local() line 474 in /Users/tbridel/Documents/1-CODES/04-PETSC/src/dm/impls/plex/plex.c
> [0]PETSC ERROR: #6 VecLoad_Plex_HDF5_Internal() line 295 in /Users/tbridel/Documents/1-CODES/04-PETSC/src/dm/impls/plex/plexhdf5.c
> [0]PETSC ERROR: #7 VecLoad_Plex() line 496 in /Users/tbridel/Documents/1-CODES/04-PETSC/src/dm/impls/plex/plex.c
> [0]PETSC ERROR: #8 VecLoad() line 953 in /Users/tbridel/Documents/1-CODES/04-PETSC/src/vec/vec/interface/vector.c
> [0]PETSC ERROR: #9 User provided function() line 0 in User file
> Do you know where it could come from ?
> I think I understand this. PETSc tries to be clever to allow you to store timesteps. It gives the HDF5 array an extra dimension. Somehow
> the Viewer has to know this. The TS does this automatically, so you have an array
>   GROUP "fields" {
>       DATASET "Solution" {
>          DATATYPE  H5T_IEEE_F64LE
>          DATASPACE  SIMPLE { ( 21, 5060, 5 ) / ( H5S_UNLIMITED, 5060, 5 ) }
> which has 21 timesteps. However, when you create a brand new Viewer, it does not know, and mistakenly thinks there is a single vector
> of length 21 * 5 = 105. You can tell your reader which timestep you want to extract using
>     https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Viewer/PetscViewerHDF5SetTimestep.html <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Viewer/PetscViewerHDF5SetTimestep.html>
>   Thanks,
>     Matt
> As for what I am doing exactly : i am using the DMPlex with a PetscFV to solve the fluid mechanics Euler equations in 3D. The PetscFV linked to the DS of the DMPlex might be why there is a /fields before the /Solution maybe .. ?
> Cheers and thank you again for your help !!
> Thibault
> Le mer. 7 avr. 2021 à 10:07, Hapla Vaclav <vaclav.hapla at erdw.ethz.ch <mailto:vaclav.hapla at erdw.ethz.ch>> a écrit :
> Dear Thibault
>> On 7 Apr 2021, at 08:18, Thibault Bridel-Bertomeu <thibault.bridelbertomeu at gmail.com <mailto:thibault.bridelbertomeu at gmail.com>> wrote:
>> Dear all,
>> I have been facing a problem with VecLoad recently, even though it seems to me I did exactly like in the examples/tutorials.
>> Basically, a program writes a vector with the HDF5 writer like this :
>>                 call DMCreateGlobalVector(dm, sol, ierr);           CHKERRA(ierr)
>>                 call VecZeroEntries(X, ierr);                     CHKERRA(ierr)
>>                 call PetscObjectSetName(X, "Solution", ierr);     CHKERRA(ierr)
>>                 < do something with X to fill it up with relevant data >
>>                 call PetscViewerCreate(PETSC_COMM_WORLD, hdf5Viewer, ierr); CHKERRA(ierr)
>>                 call PetscViewerSetType(hdf5Viewer, PETSCVIEWERHDF5, ierr); CHKERRA(ierr)
>>                 call PetscViewerFileSetMode(hdf5Viewer, FILE_MODE_WRITE, ierr); CHKERRA(ierr);
>>                 write(filename,'(A,I5.5,A)') "restart_", stepnum, ".h5"
>>                 call PetscViewerFileSetName(hdf5Viewer, trim(filename), ierr); CHKERRA(ierr)
>>                 call VecView(X, hdf5Viewer, ierr); CHKERRA(ierr)
>>                 call PetscViewerDestroy(hdf5Viewer, ierr); CHKERRA(ierr)
>> and the same program (but with different start-up options, say) re-reads such a file like this :
>>                 call VecZeroEntries(sol, ierr);                     CHKERRA(ierr)
>>                 call PetscObjectSetName(sol, "Solution", ierr);     CHKERRA(ierr)
>>                 call PetscViewerFileSetMode(hdf5Viewer, FILE_MODE_READ, ierr); CHKERRA(ierr)
>>                 call PetscViewerFileSetName(hdf5Viewer, trim(restartname), ierr); CHKERRA(ierr)
>>                 call VecLoad(sol, hdf5Viewer, ierr); CHKERRA(ierr)
>> Such a dataset can be found under this link : https://drive.google.com/file/d/1owLAx5vknNhj61_5ieAwnWOR9cmkTseL/view?usp=sharing <https://drive.google.com/file/d/1owLAx5vknNhj61_5ieAwnWOR9cmkTseL/view?usp=sharing>
> I'm just looking at the HDF5 file. The structure is like this
> > $PETSC_DIR/$PETSC_ARCH/bin/h5dump -H restart_00020.h5
> HDF5 "restart_00020.h5" {
> GROUP "/" {
>    GROUP "cell_fields" {
>       DATASET "Solution_FV solver" {
>          DATASPACE  SIMPLE { ( 21, 3884, 5 ) / ( H5S_UNLIMITED, 3884, 5 ) }
>          ATTRIBUTE "vector_field_type" {
>             DATATYPE  H5T_STRING {
>                STRSIZE 7;
>                STRPAD H5T_STR_NULLTERM;
>                CSET H5T_CSET_ASCII;
>                CTYPE H5T_C_S1;
>             DATASPACE  SCALAR
>    GROUP "fields" {
>    DATASET "time" {
>       DATASPACE  SIMPLE { ( 21, 1 ) / ( H5S_UNLIMITED, 1 ) }
>> I would like the reader to read the /fields/Solution group basically, but I am not even sure it tries to do that.
>> Anyhow, I got an error, saying that the size found in the file (105) does not match the expected size (25300). If I look at the shape of /fields/Solution it is given as (21, 5030, 5). First, it is weird, cause the 21 seems to be 1 + current iteration number ... but anyways we find the 5 variables and the 5030 cells. Only the reader seems to do 21 * 5 when it should be doing 5030 * 5 ...
>> I tried adding 'PetscViewerHDF5PushGroup(hdf5Viewer, "/fields/Solution", ierr)' to force it to read that group, but it does not change anything.
> You definitely need to push the group, unless it's the root group "/". There is no way the reader would guess the correct group if it's not the root one [and I don't think it would be a good idea to implement such searching].
> If you tried adding
> you likely pushed a wrong group. If the Vec name was set to "Solution" like in your snippet [using PetscObjectSetName()], the absolute dataset name to look up would be "/fields/Solution/Solution".
> But in your file, there's just a dataset "/fields/Solution", so its parent group is just "/fields". So please try pushing this.
> I would gladly try to reproduce your case - perhaps the error handling should be improved so that it would guide you into the right direction. But it would be helpful to know exactly what you're doing - the snippet with VecView() above should produce "/Solution" dataset but in the file you're sending, there's "/fields/Solution".
> Note also you don't need to do VecZeroEntries() before loading because VecLoad() fully rewrites the Vec data in memory anyway.
>> I would appreciate it if anyone could give me pointers on this issue ...
>> Thank you very much in advance !!
>> Thibault
> Thanks,
> Vaclav
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210407/793831b8/attachment-0001.html>
