[petsc-users] Failed to build Petsc statically linked to MKL for Windows
Thuc Bui bui at calcreek.com
Tue Sep 29 20:58:57 CDT 2020
Thank you Satish very much. You are so right in catching this error. My bad!
Here is the configuration that works for Windows 10 VS 2015 x64 Release
build, no Fortran compiler, no MPI and links statically to Intel MKL
./configure --with-cc='win32fe cl' --with-cxx='win32fe cl' --with-fc=0
--with-openmp --with-debugging=0 --with-mpi=0
--with-blas-lapack-lib="-L/cygdrive/c/PROGRA~2/INTELS~1/COMPIL~1.279/windows
/mkl/lib/intel64_win mkl_intel_lp64.lib mkl_core.lib mkl_intel_thread.lib
libiomp5md.lib"
Many thanks again for your help,
Thuc
-----Original Message-----
Sent: Tuesday, September 29, 2020 5:39 PM
To: Thuc Bui
Cc: 'petsc-users'
Subject: Re: [petsc-users] Failed to build Petsc statically linked to MKL
for Windows
> LINK : fatal error LNK1181: cannot open input file
'C:\PROGRA~2\INTELS~1\COMPIL~1.279\windows\mkl\lib\mkl_intel_lp64.lib'
please verify if the file exists. What do you have for:
ls
/cygdrive/c/PROGRA~2/INTELS~1/COMPIL~1.279/windows/mkl/lib/mkl_intel_lp64.li
b
Satish
On Tue, 29 Sep 2020, Thuc Bui wrote:
> Hi Barry & Satish,
> I also did a configuration to have a full path for each library as follows
--with-blas-lapack-lib="/cygdrive/c/PROGRA~2/INTELS~1/COMPIL~1.279/windows/m
> kl/lib/mkl_intel_lp64.lib
> /cygdrive/c/PROGRA~2/INTELS~1/COMPIL~1.279/windows/mkl/lib/mkl_core.lib
/cygdrive/c/PROGRA~2/INTELS~1/COMPIL~1.279/windows/mkl/lib/mkl_intel_thread.
> lib
> /cygdrive/c/PROGRA~2/INTELS~1/COMPIL~1.279/windows/mkl/lib/libiomp5md.lib"
> and also got the same error message. Attached is the configure.log.
>          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for
> details):
> You set a value for --with-blaslapack-lib=<lib>, but
['/cygdrive/c/PROGRA~2/INTELS~1/COMPIL~1.279/windows/mkl/lib/mkl_intel_lp64.
> lib',
> '/cygdrive/c/PROGRA~2/INTELS~1/COMPIL~1.279/windows/mkl/lib/mkl_core.lib',
'/cygdrive/c/PROGRA~2/INTELS~1/COMPIL~1.279/windows/mkl/lib/mkl_intel_thread
> .lib',
'/cygdrive/c/PROGRA~2/INTELS~1/COMPIL~1.279/windows/mkl/lib/libiomp5md.lib']
> cannot be used
> Thanks,
> Thuc
> From: Thuc Bui [mailto:bui at calcreek.com]
> Sent: Tuesday, September 29, 2020 5:17 PM
> To: petsc-users
> Cc: Barry Smith
> Subject: RE: [petsc-users] Failed to build Petsc statically linked to MKL
> for Windows
> Hi Barry & Satish,
> I really appreciate you are getting back to me. Because libiomp5md.lib is
> not in the mkl/lib directory, I just copy it to the same directory and per
> your suggestion use the followings
> /mkl/lib mkl_intel_lp64.lib mkl_core.lib mkl_intel_thread.lib
> libiomp5md.lib"
> Unfortunately, I got the same error message as below. I am attaching
> configure log, and hopefully you can see what I am doing icorrectly.
> Many thanks,
> Thuc
> ['-L/cygdrive/c/PROGRA~2/INTELS~1/COMPIL~1.279/windows/mkl/lib',
> 'mkl_intel_lp64.lib', 'mkl_core.lib', 'mkl_intel_thread.lib',
> 'libiomp5md.lib'] cannot be used
> From: Satish Balay [mailto:balay at mcs.anl.gov]
> Sent: Tuesday, September 29, 2020 4:12 PM
> To: Thuc Bui
> Cc: petsc-users at mcs.anl.gov
> for Windows
https://software.intel.com/content/www/us/en/develop/articles/intel-mkl-link
> -line-advisor.html
> Checking for MS compilers - [MKL2018+] it gives:
> mkl_intel_lp64.lib mkl_intel_thread.lib mkl_core.lib libiomp5md.lib
> i.e no -Wl,--start-group [MS compiler most likely does not use this
option]
> So you can try:
--with-blaslapack-lib="-L/cygdrive/c/PROGRA~2/INTELS~1/COMPIL~1.279/windows/
> mkl/lib/ mkl_intel_lp64.lib mkl_intel_thread.lib mkl_core.lib
> libiomp5md.lib"
> Satish
> > Dear Petsc Users,
> > I have successfully built Petsc v3.13.5 for Windows 10 VS2015 without
> > Fortran compiler and without MPI. These successful  builds are either
> > linked statically with Blas-Lapack or dynamically with Intel MKL.
> > However, when linking dynamically to MKL, I would have to include 4
> > more Intel DLLs for building applications. I would like to have Petsc
> > linking statically to MKL to avoid having these extra DLLs, but have
> > not been successful. Here is how I run configure for static link
> > --with-blas-lapack-lib="-Wl,--start-group
> > p64.li b
> > b
> > lib -Wl,--end-group"
> > I got this configuration error,
> > === TESTING: checkLib from
> > config.packages.BlasLapack(config/BuildSystem/config/pack*************
for
> > details):
> > ['-Wl,--start-group',
> > lp64.l
> > ib',
> > ib',
> > thread .lib', '-Wl,--end-group'] cannot be used
> > Can someone point me to a proper syntax to link to MKL statically?
> > Attached is the configure.log if you need it.
> > I have also tried unsuccessfuly,
> > dows/m
> > b
> > lib"
> > or
> > indows /mkl/lib -lmkl_intel_lp64.lib -lmkl_core.lib
> > -lmkl_intel_thread.lib",
> > or
> > indows /mkl/lib mkl_intel_lp64.lib mkl_core.lib mkl_intel_thread.lib"
> > and all gave the similar error message.
> > Many thanks in advance for your help,
> > Thuc Bui
> > Senior R&D Engineer
> > Calabazas Creek Research, Inc.
> > (650) 948-5361 (Office)
> > (650) 948-7562 (Fax)
