[petsc-users] using real and complex together
Barry Smith bsmith at petsc.dev
Mon Sep 28 18:03:29 CDT 2020
> On Sep 28, 2020, at 5:32 PM, Sam Guo <sam.guo at cd-adapco.com> wrote:
> Another idea I am pursuing is to prefix real and complex using some compiler flags. Didn’t figure out how to do this cross platform for shared libs yet.
   This is very hairy because there are some symbols that can be common and some that are not common. I could never figure out a rational general purpose approach.
   This is definitely something we need to support in any future refactorization https://gitlab.com/petsc/petsc/-/issues/643 <https://gitlab.com/petsc/petsc/-/issues/643>
> On Monday, September 28, 2020, Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>> wrote:
> On Mon, Sep 28, 2020 at 5:01 PM Sam Guo <sam.guo at cd-adapco.com <mailto:sam.guo at cd-adapco.com>> wrote:
> Hi Matt,
>    Since I use MUMPS as preconditioner, complex uses too much memory if my input matrix is real. Ideally if I can compile real and complex into different symbols (like MUMPS) , I can load both version without conflict.
> What I mean to say is that it would be great if it were as simple as using two different symbols, but unfortunately the problem is more difficult. I was trying to use
> the example of templates. This would be a very intrusive change no matter what technology you are using.
> So your main memory usage is from the MUMPS factorization, and you cannot afford to double that usage?
> You could consider writing a version of AIJ that stores real entries, but allows complex vector values. It would promote to complex for the row dot product.
> However, you would also have to do the same work for all the solves you do with MUMPS.
> I think it would be much easier to just decompose your complex work into real and imaginary parts and use PETSc with real scalars to compute them separately.
> Since you know your matrices have 0 imaginary part, this becomes very straightforward.
>   Thanks,
>       Matt
> Thanks,
> Sam
> On Mon, Sep 28, 2020 at 12:52 PM Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>> wrote:
> On Mon, Sep 28, 2020 at 3:43 PM Sam Guo <sam.guo at cd-adapco.com <mailto:sam.guo at cd-adapco.com>> wrote:
> Hi Stefano and PETSc dev team,
>    I want to try your suggestion to always load complex version of PETSc but if my input matrix A is real, I want to create shell matrix to matrix-vector and factorization using real only.
> I do not think that will work as you expect. I will try to explain below.
>    I still need to understand how MatRealPart works. Does it just zero out the image numerical values or does it delete the image memory?
> When we have complex values, we use the "complex" type to allocate and store them. Thus you cannot talk about just the memory to store imaginary parts.
> MatRealPart sets the imaginary parts of all the matrix elements to zero.
> If my input matrix A is real, how do I create a shell matrix to matrix -vector multiplication y=A*x where A is real, PestcScalar = complex, x and y are Vec? I notice there is a VecRealPart but it seems it just zeros the image numerical values. It seems I still have to create a PetscReal pointer  to copy the real part of PetacScalar pointers like following. Can you comment on it?
> What you suggest would mean rewriting the matrix multiplication algorithm by hand after extracting the values. I am not sure if this
> is really what you want to do. Is the matrix memory really your limiting factor? Even if you tried to do this with templates, the memory
> from temporaries would be very hard to control.
>   Thanks,
>      Matt
> Thanks,
> Sam
> PetscScalar *px = nullptr;
> VecGetArrayRead(x, &px);
> PetscScalar *py = nullptr;
> VecGetArray(y, &py);
> int localSize = 0;
> VecGetLocalSize(x, &localSize);
> std::vector<PetasReal> realX(localSize); // I am using c++ to call PETSc
> //retrieve real part
> for(int i = 0; i < localSize; i++)  realX[i] = PetscRealPart(px[i]);
> // do real matrix-vector multiplication
> // realY=A*realX
> // here where realY is std::vector<PetscReal>
> //put real part back to py
>   for(int i = 0; i < localSize; i++)  pv[i] = realY[i];
> VecRestoreArray(y,&py);
> On Tue, May 26, 2020 at 1:49 PM Sam Guo <sam.guo at cd-adapco.com <mailto:sam.guo at cd-adapco.com>> wrote:
> Thanks
> On Tuesday, May 26, 2020, Stefano Zampini <stefano.zampini at gmail.com <mailto:stefano.zampini at gmail.com>> wrote:
> All the solvers/matrices/vectors works for PetscScalar types (i.e. in your case complex)
> If you need to solve for the real part only, you can duplicate the matrix and call MatRealPart to zero out the imaginary part. But the solve will always run in the complex space
> You should not be worried about doubling the memory for a matrix (i.e. real and imaginary part)
>> On May 26, 2020, at 11:28 PM, Sam Guo <sam.guo at cd-adapco.com <mailto:sam.guo at cd-adapco.com>> wrote:
>> complex version is needed since matrix sometimes is real and sometimes is complex. I want to solve real matrix without allocating memory for imaginary part((except eigen pairs).
>> On Tuesday, May 26, 2020, Zhang, Hong <hzhang at mcs.anl.gov <mailto:hzhang at mcs.anl.gov>> wrote:
>> You can build PETSc with complex version, and declare some variables as 'PETSC_REAL'.
>> Hong
>> From: petsc-users <petsc-users-bounces at mcs.anl.gov <mailto:petsc-users-bounces at mcs.anl.gov>> on behalf of Sam Guo <sam.guo at cd-adapco.com <mailto:sam.guo at cd-adapco.com>>
>> Sent: Tuesday, May 26, 2020 1:00 PM
>> To: PETSc <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>>
>> Subject: [petsc-users] using real and complex together
>> Dear PETSc dev team,
>>    Can I use both real and complex versions together?
>> Thanks,
>> Sam
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200928/8a91cfaf/attachment-0001.html>
