[petsc-users] Regarding help with MatGetSubMatrix parallel use
Krishnan, Gautham
gautham3 at illinois.edu
Wed Sep 23 15:11:49 CDT 2020
Hello,
For a CFD code being developed with FORTRAN and MPI, I am using PETSC matrices and for a particular operation, I require to extract a submatrix(n-1 x n-1) of a matrix created (n x n). However using the petsc MatGetSubMatrix works for serial runs but fails when the domain is split up over PEs- I suspect the indexing changed for parallel runs and hence the global indexing that worked for serial case just shuffles around matrix entries in parallel undesirably. I would like to ask whether anybody could offer some guidance regarding this. I would like to note that the 2D domain is split along both x and y axes for parallel runs on multiple PEs.
Gautham Krishnan,
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200923/50a24d33/attachment.html>
