[petsc-users] AMG for block matrices
Mark Adams mfadams at lbl.gov
Wed Sep 23 08:26:40 CDT 2020
Generally you do want to use FieldSplit but Vanka might work.
I'm not sure what to use as the smoother KSP. -mg_levels_ksp_type [gmres |
richardson]. If you use richardson you will probably want to fiddle with
the damping.
On Tue, Sep 22, 2020 at 11:23 PM Barry Smith <bsmith at petsc.dev> wrote:
>   Raju,
>     If you call MatSetBlockSize(mat,4) then GAMG will keep the 4 variables
> together through all the levels.
>     You might consider using the point block Jacobi smoother with it
> instead of the default Jacobi smoother -mg_levels_pc_type pbjacobi
>     There is also PCPATCH which supports Vanka smoothing (though it is to
> well hidden) PCPatchSetConstructType(pc,PC_PATCH_VANKA)
> -pc_patch_construct_type vanka
>     For coupled Navier stokes you might also consider using PCFIELDSPLIT
> and GAMG just for the pressure solve inside it.
>   Barry
> > On Sep 22, 2020, at 9:24 PM, Raju Mandhapati via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
> > Hello,
> > Does Petsc have an option to solve block matrices using AMG
> solver/preconditioner. My block matrix is coming from solving u,v,w,p
> (coupled Navier stokes) at each cell.
> > thanks
> > Raju.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200923/e85e58ee/attachment.html>
