[petsc-users] osx error
Mark Adams mfadams at lbl.gov
Fri Sep 18 10:07:08 CDT 2020
Let me know if you want anything else.
On Fri, Sep 18, 2020 at 11:05 AM Mark Adams <mfadams at lbl.gov> wrote:
> On Fri, Sep 18, 2020 at 11:04 AM Satish Balay <balay at mcs.anl.gov> wrote:
>> On Fri, 18 Sep 2020, Satish Balay via petsc-users wrote:
>> > > >> 07:41 master *= ~/Codes/petsc$ ping -c 2 MarksMac-302.local
>> > > >> PING marksmac-302.local (127.0.0.1): 56 data bytes
>> > So it is resolving MarksMac-302.local as 127.0.0.1 - but ping is not
>> responding?
>> > I know some machines don't respond to external ping [and firewalls can
>> block it] but don't really know if they always respond to internal ping or
>> not.
>> > If some machines don't respond to internal ping  - then we can't use
>> ping test in configure [it will create false negatives - as in this case]
>> BTW: To confirm, please try:
>> ping 127.0.0.1
> 11:02 master *= ~/Codes/petsc$ sudo vi /etc/hosts
> 11:02 master *= ~/Codes/petsc$ ping 127.0.0.1
> PING 127.0.0.1 (127.0.0.1): 56 data bytes
> Request timeout for icmp_seq 0
> Request timeout for icmp_seq 1
> Request timeout for icmp_seq 2
> Request timeout for icmp_seq 3
> Request timeout for icmp_seq 4
> Request timeout for icmp_seq 5
> Request timeout for icmp_seq 6
> Request timeout for icmp_seq 7
> Request timeout for icmp_seq 8
> Request timeout for icmp_seq 9
> Request timeout for icmp_seq 10
> Request timeout for icmp_seq 11
> Request timeout for icmp_seq 12
> Request timeout for icmp_seq 13
> Request timeout for icmp_seq 14
> Request timeout for icmp_seq 15
> Request timeout for icmp_seq 16
> Request timeout for icmp_seq 17
> Request timeout for icmp_seq 18
> Request timeout for icmp_seq 19
> Request timeout for icmp_seq 20
> Request timeout for icmp_seq 21
> still going ......
>> Satish
>> > Mark, can you remove the line that you added to /etc/hosts - i.e:
>> > 127.0.0.1 MarksMac-302.local
>> > And now rerun MPI tests. Do they work or fail?
>> > [this is to check if this test is a false positive on your machine]
>> > Satish
>> > On Fri, 18 Sep 2020, Mark Adams wrote:
>> > > On Fri, Sep 18, 2020 at 7:51 AM Matthew Knepley <knepley at gmail.com>
>> wrote:
>> > > > On Fri, Sep 18, 2020 at 7:46 AM Mark Adams <mfadams at lbl.gov> wrote:
>> > > >> Oh you did not change my hostname:
>> > > >> 07:37 master *= ~/Codes/petsc$ hostname
>> > > >> MarksMac-302.local
>> > > >> --- marksmac-302.local ping statistics ---
>> > > >> 2 packets transmitted, 0 packets received, 100.0% packet loss
>> > > >> 07:42 2 master *= ~/Codes/petsc$
>> > > > This does not make sense to me. You have
>> > > > in /etc/hosts,
>> > > 09:07  ~/.ssh$ cat /etc/hosts
>> > > # Host Database
>> > > # localhost is used to configure the loopback interface
>> > > # when the system is booting.  Do not change this entry.
>> > > 127.0.0.1 localhost
>> > > 255.255.255.255 broadcasthost
>> > > 127.0.0.1    MarksMac-5.local
>> > > 127.0.0.1 243.124.240.10.in-addr.arpa.private.cam.ac.uk
>> > > 09:07  ~/.ssh$
>> > > > but you cannot resolve that name?
>> > > >   Matt
>> > > >> BTW, I used to get messages about some network issue and 'changing
>> host
>> > > >> name to MarksMac-[x+1].local'. That is, the original hostname
>> > > >> was MarksMac.local, then I got a message about changing
>> > > >> to MarksMac-1.local, etc. I have not seen these messages for
>> months but
>> > > >> apparently this process has continued unabated.
>> > > >> On Thu, Sep 17, 2020 at 11:10 PM Satish Balay via petsc-users <
>> > > >> petsc-users at mcs.anl.gov> wrote:
>> > > >>> On Thu, 17 Sep 2020, Matthew Knepley wrote:
>> > > >>> > On Thu, Sep 17, 2020 at 8:33 PM Barry Smith <bsmith at petsc.dev>
>> wrote:
>> > > >>> > > > On Sep 17, 2020, at 4:59 PM, Satish Balay via petsc-users <
>> > > >>> > > > Here is a fix:
>> > > >>> > > > echo 127.0.0.1 `hostname` | sudo tee -a /etc/hosts
>> > > >>> > >  Satish,
>> > > >>> > >    I don't think you want to be doing this on a Mac (on
>> anything?)
>> > > >>> On a
>> > > >>> > > Mac based on the network configuration etc as it boots up and
>> as
>> > > >>> networks
>> > > >>> > > are accessible or not (wi-fi) it determines what hostname
>> should be,
>> > > >>> one
>> > > >>> > > should never being hardwiring it to some value.
>> > > >>> > Satish is just naming the loopback interface. I did this on all
>> my
>> > > >>> former
>> > > >>> > Macs.
>> > > >>> Yes - this doesn't change the hostname. Its just adding an entry
>> for
>> > > >>> gethostbyname - for current hostname.
>> > > >>> Sure - its best to not do this when one has a proper IP name [like
>> > > >>> foo.mcs.anl.gov] - but its useful when one has a hostname like
>> > > >>> "MarksMac-302.local" -that is not DNS resolvable
>> > > >>> Even if the machine is moved to a different network with a
>> different
>> > > >>> name - the current entry won't cause problems [but will need
>> another entry
>> > > >>> for the new host name - if this new name is also not DNS
>> resolvable]
>> > > >>> Its likely this file is a generated file on  macos  - so might
>> get reset
>> > > >>> on reboot - or some network change? [if this is the case - the
>> change won't
>> > > >>> be permanent]
>> > > >>> Satish
>> > > > What most experimenters take for granted before they begin their
>> > > > experiments is infinitely more interesting than any results to
>> which their
>> > > > experiments lead.
>> > > > -- Norbert Wiener
>> > > > https://www.cse.buffalo.edu/~knepley/
>> > > > <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200918/ee7cd0c4/attachment.html>
