[petsc-users] osx error
Barry Smith bsmith at petsc.dev
Fri Sep 18 10:05:15 CDT 2020
  I have turned on my Mac Firewall and now get the same behavior as Mark.
  I have the Automatically allow builtin software to receive incoming connections checked So /sbin/ping must not be a builtin software
  I then tried to unblock /sbin/ping from the firewall with
sudo  /usr/libexec/ApplicationFirewall/socketfilterfw --add  /sbin/ping
sudo  /usr/libexec/ApplicationFirewall/socketfilterfw --unblock  /sbin/ping
Incoming connection to the application is permitted
ping still indicates Request timeout for icmp_seq 0
But
$ /usr/sbin/traceroute `hostname`
traceroute: Warning: Barrys-MacBook-Pro-3.local has multiple addresses; using 127.0.0.1
traceroute to barrys-macbook-pro-3.local (127.0.0.1), 64 hops max, 52 byte packets
 1  localhost (127.0.0.1)  0.539 ms  0.101 ms  0.067 ms
works with the Firewall on. In fact traceroute works with the Automatically allow builtin software to receive incoming connections NOT checked.
traceroute also fails like ping when vpn is turned on for my Mac.
Mark,
    You need not bother with the lists of tasks I sent you. Thanks
  Barry
> On Sep 18, 2020, at 9:28 AM, Satish Balay via petsc-users <petsc-users at mcs.anl.gov> wrote:
>>>> 07:41 master *= ~/Codes/petsc$ ping -c 2 MarksMac-302.local
>>>> PING marksmac-302.local (127.0.0.1): 56 data bytes
> So it is resolving MarksMac-302.local as 127.0.0.1 - but ping is not responding?
> I know some machines don't respond to external ping [and firewalls can block it] but don't really know if they always respond to internal ping or not.
> If some machines don't respond to internal ping  - then we can't use ping test in configure [it will create false negatives - as in this case]
> Mark, can you remove the line that you added to /etc/hosts - i.e:
> 127.0.0.1 MarksMac-302.local
> And now rerun MPI tests. Do they work or fail?
> [this is to check if this test is a false positive on your machine]
> Satish
> On Fri, 18 Sep 2020, Mark Adams wrote:
>> On Fri, Sep 18, 2020 at 7:51 AM Matthew Knepley <knepley at gmail.com> wrote:
>>> On Fri, Sep 18, 2020 at 7:46 AM Mark Adams <mfadams at lbl.gov> wrote:
>>>> Oh you did not change my hostname:
>>>> 07:37 master *= ~/Codes/petsc$ hostname
>>>> MarksMac-302.local
>>>> --- marksmac-302.local ping statistics ---
>>>> 2 packets transmitted, 0 packets received, 100.0% packet loss
>>>> 07:42 2 master *= ~/Codes/petsc$
>>> This does not make sense to me. You have
>>> in /etc/hosts,
>> 09:07  ~/.ssh$ cat /etc/hosts
>> # Host Database
>> # localhost is used to configure the loopback interface
>> # when the system is booting.  Do not change this entry.
>> 127.0.0.1 localhost
>> 255.255.255.255 broadcasthost
>> 127.0.0.1    MarksMac-5.local
>> 127.0.0.1 243.124.240.10.in-addr.arpa.private.cam.ac.uk
>> 09:07  ~/.ssh$
>>> but you cannot resolve that name?
>>>  Matt
>>>> BTW, I used to get messages about some network issue and 'changing host
>>>> name to MarksMac-[x+1].local'. That is, the original hostname
>>>> was MarksMac.local, then I got a message about changing
>>>> to MarksMac-1.local, etc. I have not seen these messages for months but
>>>> apparently this process has continued unabated.
>>>> On Thu, Sep 17, 2020 at 11:10 PM Satish Balay via petsc-users <
>>>>> On Thu, 17 Sep 2020, Matthew Knepley wrote:
>>>>>> On Thu, Sep 17, 2020 at 8:33 PM Barry Smith <bsmith at petsc.dev> wrote:
>>>>>>>> On Sep 17, 2020, at 4:59 PM, Satish Balay via petsc-users <
>>>>>>>> Here is a fix:
>>>>>>>> echo 127.0.0.1 `hostname` | sudo tee -a /etc/hosts
>>>>>>> Satish,
>>>>>>>   I don't think you want to be doing this on a Mac (on anything?)
>>>>> On a
>>>>>>> Mac based on the network configuration etc as it boots up and as
>>>>> networks
>>>>>>> are accessible or not (wi-fi) it determines what hostname should be,
>>>>> one
>>>>>>> should never being hardwiring it to some value.
>>>>>> Satish is just naming the loopback interface. I did this on all my
>>>>> former
>>>>>> Macs.
>>>>> Yes - this doesn't change the hostname. Its just adding an entry for
>>>>> gethostbyname - for current hostname.
>>>>> Sure - its best to not do this when one has a proper IP name [like
>>>>> foo.mcs.anl.gov] - but its useful when one has a hostname like
>>>>> "MarksMac-302.local" -that is not DNS resolvable
>>>>> Even if the machine is moved to a different network with a different
>>>>> name - the current entry won't cause problems [but will need another entry
>>>>> for the new host name - if this new name is also not DNS resolvable]
>>>>> Its likely this file is a generated file on  macos  - so might get reset
>>>>> on reboot - or some network change? [if this is the case - the change won't
>>>>> be permanent]
>>>>> Satish
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/
>>> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200918/a44e8ab7/attachment.html>
