[petsc-users] 1D parallel split of dense matrix
Pierre Jolivet pierre.jolivet at enseeiht.fr
Fri Sep 18 00:44:01 CDT 2020
Hello Yann,
MatGetColumnVector() is indeed kind of slow and there is a hard copy under the hood.
Better to use MatDenseGetColumnVec()/MatDenseRestoreColumn() which is more efficient (https://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/Mat/MatDenseGetColumn.html <https://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/Mat/MatDenseGetColumn.html>), or do what Barry suggested.
KSPSetMatSolveBlockSize() is a rather advanced option, it’s only used by KSPHPDDM, not KSPPREONLY (I think?), which I’m guessing is what you are using with a full LU.
The idea behind this option, borrowed from MUMPS option ICNTL(27), is to solve multiple systems with multiple RHS.
So you split AX = B into A[X_0, X_1, …, X_p] = [B_0, B_1, …, B_p] where all blocks are of width at most KSPMatSolveBlockSize.
It’s useful when you have a large number of right-hand sides and it’s becoming too memory-demanding to fit everything in memory, e.g., when doing block Krylov methods or out-of-core LU factorization.
However, if everything fits, it’s best to just do KSPSetMatSolveBlockSize(ksp, PETSC_DECIDE) or don’t call that routine at all, which will default to a single solve with a single thick block.
Direct solvers scale really nicely with the number of right-hand sides, thanks to BLAS3, so the higher the number of RHS, the better the efficiency.
Pierre
> On 17 Sep 2020, at 11:36 PM, Yann Jobic <yann.jobic at univ-amu.fr> wrote:
> Hi Stefano,
> You're right, i just switched the rows and colomns, and it's working fine. However, i've done this in order to have better performance when i access the rows, with MatGetRow. With this order, i need MatGetColumnVector, which is believe  is kind of slow, as stated in the comments of the implementation (but i couldn't find it again, maybe i was looking at an old implementation?).
> I still don't understand why i can not use the transpose of this matrix, as i give the right parallel decomposition. It should be a bijective operation no ?
> I think i'll be using the KSPMatSolve of Pierre, so i don't have to redevelop this part.
> Thanks a lot,
> Yann
> Le 9/17/2020 à 6:29 PM, Stefano Zampini a écrit :
>> Yann
>>  you want to have the number of columns equal to the number of rhs. Not the number of rows.
>> This is also consistent in terms of logical layouts. Simply create and dump the matrix this way and you can read in parallel splitting yhe rows ( ie the logical size per process of the vectors)
>> Il Gio 17 Set 2020, 18:09 Pierre Jolivet <pierre.jolivet at enseeiht.fr <mailto:pierre.jolivet at enseeiht.fr>> ha scritto:
>>    Hello Yann,
>>    This is probably not fully answering your question, but the proper
>>    way to solve a system with N RHS is _not_ to use KSPSolve(), but
>>    instead KSPMatSolve(), cf.
>>    https://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/KSP/KSPMatSolve.html.
>>    If you are tracking master (from the GitLab repository), it’s
>>    available out of the box. If you are using the release tarballs, it
>>    will be available in 3.14.0 scheduled to be released in a couple of
>>    days.
>>    If you want to know more about the current status of block solvers
>>    in PETSc, please feel free to have a look at this preprint:
>>    http://jolivet.perso.enseeiht.fr/article.pdf
>>    If you are using a specific PC which is not “multi-RHS ready”, see
>>    the list at the top of page 5, please let me know and I’ll tell you
>>    how easy to support it.
>>    Thanks,
>>    Pierre
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200918/27ecd8a6/attachment.html>
