[petsc-users] osx error
Jacob Faibussowitsch
jacob.fai at gmail.com
Thu Sep 17 17:02:21 CDT 2020
+1 to this fix, I had similar issues a while back except I was getting the following error during make check (or running any mpi code for that matter) after petsc was built:
Fatal error in PMPI_Init_thread: Other MPI error, error stack:
MPIR_Init_thread(467)..............:
MPID_Init(177).....................: channel initialization failed
MPIDI_CH3_Init(70).................:
MPID_nem_init(319).................:
MPID_nem_tcp_init(171).............:
MPID_nem_tcp_get_business_card(418):
MPID_nem_tcp_init(377).............: gethostbyname failed, localhost (errno 3)
Best regards,
(Jacob Fai - booss - oh - vitch)
Cell: (312) 694-3391
> On Sep 17, 2020, at 17:59, Satish Balay via petsc-users <petsc-users at mcs.anl.gov> wrote:
> Here is a fix:
> echo 127.0.0.1 `hostname` | sudo tee -a /etc/hosts
> Satish
> On Thu, 17 Sep 2020, Matthew Knepley wrote:
>> We should have an option to disable the test.
>> Matt
>> On Thu, Sep 17, 2020 at 5:31 PM Satish Balay via petsc-users <
>>> On Thu, 17 Sep 2020, Mark Adams wrote:
>>>> I rebased over master and started getting this error.
>>>> I did reinstall MPICH (brew) recently.
>>>> Any ideas?
>>>> Thanks,
>>>> Mark
>>> Exception: Your hostname will not work with MPI, perhaps you have VPN
>>> running whose network settings may not play well with MPI or your network
>>> is misconfigured
>>> Ok - this is a new test that got added to check for broken network that
>>> breaks MPI.
>>> Here is the check:
>>> Executing: ping -c 2 MarksMac-302.local
>>> The check says you have broken network settings. [as its not responding to
>>> ping.]
>>> Does MPI work fine on this box? You can try disabling this check
>>> (manually) - and do the build, and run
>>> Does MPI run fine?
>>> Satish
>>> diff --git a/config/BuildSystem/config/packages/MPI.py
>>> b/config/BuildSystem/config/packages/MPI.py
>>> index 2e130fdcfe..8464de6773 100644
>>> --- a/config/BuildSystem/config/packages/MPI.py
>>> +++ b/config/BuildSystem/config/packages/MPI.py
>>> @@ -267,7 +267,7 @@ shared libraries and run with
>>> --known-mpi-shared-libraries=1')
>>> if ret != 0:
>>> raise RuntimeError(errormessage+" Return code %s\n" % ret)
>>> except:
>>> - raise RuntimeError("Exception: "+errormessage)
>>> + pass
>>> else:
>>> self.logPrint("Unable to get result from hostname, skipping
>>> ping check\n")
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200917/bc82e129/attachment-0001.html>
