[petsc-users] osx error
Satish Balay
balay at mcs.anl.gov
Thu Sep 17 16:59:38 CDT 2020
Here is a fix:
echo 127.0.0.1 `hostname` | sudo tee -a /etc/hosts
Satish
On Thu, 17 Sep 2020, Matthew Knepley wrote:
> We should have an option to disable the test.
> Matt
> On Thu, Sep 17, 2020 at 5:31 PM Satish Balay via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
> > On Thu, 17 Sep 2020, Mark Adams wrote:
> > > I rebased over master and started getting this error.
> > > I did reinstall MPICH (brew) recently.
> > > Any ideas?
> > > Thanks,
> > > Mark
> > Exception: Your hostname will not work with MPI, perhaps you have VPN
> > running whose network settings may not play well with MPI or your network
> > is misconfigured
> > Ok - this is a new test that got added to check for broken network that
> > breaks MPI.
> > Here is the check:
> > Executing: ping -c 2 MarksMac-302.local
> > The check says you have broken network settings. [as its not responding to
> > ping.]
> > Does MPI work fine on this box? You can try disabling this check
> > (manually) - and do the build, and run
> > Does MPI run fine?
> > Satish
> > diff --git a/config/BuildSystem/config/packages/MPI.py
> > b/config/BuildSystem/config/packages/MPI.py
> > index 2e130fdcfe..8464de6773 100644
> > --- a/config/BuildSystem/config/packages/MPI.py
> > +++ b/config/BuildSystem/config/packages/MPI.py
> > @@ -267,7 +267,7 @@ shared libraries and run with
> > --known-mpi-shared-libraries=1')
> > if ret != 0:
> > raise RuntimeError(errormessage+" Return code %s\n" % ret)
> > except:
> > - raise RuntimeError("Exception: "+errormessage)
> > + pass
> > else:
> > self.logPrint("Unable to get result from hostname, skipping
> > ping check\n")
