[petsc-users] osx error
Satish Balay
balay at mcs.anl.gov
Thu Sep 17 16:31:23 CDT 2020
On Thu, 17 Sep 2020, Mark Adams wrote:
> I rebased over master and started getting this error.
> I did reinstall MPICH (brew) recently.
> Any ideas?
> Thanks,
> Mark
Exception: Your hostname will not work with MPI, perhaps you have VPN running whose network settings may not play well with MPI or your network is misconfigured
Ok - this is a new test that got added to check for broken network that breaks MPI.
Here is the check:
Executing: ping -c 2 MarksMac-302.local
The check says you have broken network settings. [as its not responding to ping.]
Does MPI work fine on this box? You can try disabling this check (manually) - and do the build, and run
Does MPI run fine?
Satish
diff --git a/config/BuildSystem/config/packages/MPI.py b/config/BuildSystem/config/packages/MPI.py
index 2e130fdcfe..8464de6773 100644
--- a/config/BuildSystem/config/packages/MPI.py
+++ b/config/BuildSystem/config/packages/MPI.py
@@ -267,7 +267,7 @@ shared libraries and run with --known-mpi-shared-libraries=1')
if ret != 0:
raise RuntimeError(errormessage+" Return code %s\n" % ret)
except:
- raise RuntimeError("Exception: "+errormessage)
+ pass
else:
self.logPrint("Unable to get result from hostname, skipping ping check\n")
