[petsc-users] [EXT]Re: Is using PETSc appropriate for this problem
Alexander B Prescott
alexprescott at email.arizona.edu
Thu Sep 17 13:53:48 CDT 2020
Thank you all for your input. Matt is right, I cannot batch as this
formulation must be done sequentially.
>> Sounds a bit like a non-smoother (Gauss-Seidel type), speculating based
on these few words.
Barry, it is similar to a Gauss-Seidel solver in that solution updates from
previous solves are used in the most recent Newton solve, though I'm not
exactly sure what you mean by "non-smoother".
Best,
Alexander
On Thu, Sep 17, 2020 at 6:06 AM Matthew Knepley <knepley at gmail.com> wrote:
> *External Email*
> On Thu, Sep 17, 2020 at 12:23 AM Jed Brown <jed at jedbrown.org> wrote:
>> Alexander B Prescott <alexprescott at email.arizona.edu> writes:
>> >> Are the problems of varying nonlinearity, that is will some
>> converge
>> >> with say a couple of Newton iterations while others require more, say
>> 8 or
>> >> more Newton steps?
>> > The nonlinearity should be pretty similar, the problem setup is the
>> same at
>> > every node but the global domain needs to be traversed in a specific
>> order.
>> It sounds like you may have a Newton solver now for each individual
>> problem? If so, could you make a histogram of number of iterations
>> necessary to solve? Does it have a long tail or does every problem take 3
>> and 4 iterations (for example).
>> If there is no long tail, then you can batch. If there is a long tail,
>> you really want a solver that does one problem at a time, or a more dynamic
>> system that checks which have completed and shrinks the active problem
>> down. (That complexity has a development and execution time cost.)
> He cannot batch if the solves are sequential, as he says above.
> Matt
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
Alexander Prescott
PhD Candidate, The University of Arizona
Department of Geosciences
1040 E. 4th Street
Tucson, AZ, 85721
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200917/97144c0c/attachment.html>
