[petsc-users] Overhead in snes function calls
Thu Sep 17 12:05:00 CDT 2020
On Thu, Sep 17, 2020 at 12:00 PM Adolfo Rodriguez <adantra at gmail.com> wrote:
> I am porting a non-linear solution problem implemented explicitly to an
> snes implementation. Everything seems to be working fine, except for the
> fact that function calls done from snes to my jacobian and residual
> construction subroutines are slower than the regular direct call to the
> same subroutines (I hope this is clear). I wonder if somebody have observed
> this behavior and found a solution.
It is not quite clear. I do not see a way that the calls themselves are
slower, but perhaps there are intervening computations? How are you timing
things.
     Matt
> Regards,
> Adolfo
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200917/488840b5/attachment.html>
