[petsc-users] [EXT]Re: Is using PETSc appropriate for this problem
Jed Brown
jed at jedbrown.org
Wed Sep 16 23:23:23 CDT 2020
Alexander B Prescott <alexprescott at email.arizona.edu> writes:
>> Are the problems of varying nonlinearity, that is will some converge
>> with say a couple of Newton iterations while others require more, say 8 or
>> more Newton steps?
> The nonlinearity should be pretty similar, the problem setup is the same at
> every node but the global domain needs to be traversed in a specific order.
It sounds like you may have a Newton solver now for each individual problem? If so, could you make a histogram of number of iterations necessary to solve? Does it have a long tail or does every problem take 3 and 4 iterations (for example).
If there is no long tail, then you can batch. If there is a long tail, you really want a solver that does one problem at a time, or a more dynamic system that checks which have completed and shrinks the active problem down. (That complexity has a development and execution time cost.)
