[petsc-users] How to activate the modified Gram-Schmidt orthogonalization process in Fortran?
Zhuo Chen chenzhuotj at gmail.com
Fri Sep 11 15:37:57 CDT 2020
Hi Matthew,
I am sorry if I misunderstood. Do you mean the modified Gram-Schmidt will
be working for the first time but not for the subsequent times or the
reverse? I have checked the output of a complete loop, and it print out the
same lines, i.e.,
KSP Object: 4 MPI processes
  type: gmres
    restart=30, using Modified Gram-Schmidt Orthogonalization
    happy breakdown tolerance 1e-30
  maximum iterations=10000, initial guess is zero
  tolerances:  relative=1e-08, absolute=1e-50, divergence=10000.
  left preconditioning
  using PRECONDITIONED norm type for convergence test
 in each loop.
On Fri, Sep 11, 2020 at 2:17 PM Matthew Knepley <knepley at gmail.com> wrote:
> On Fri, Sep 11, 2020 at 4:10 PM Zhuo Chen <chenzhuotj at gmail.com> wrote:
>> Hi Matthew,
>> Yes. These four lines are in a do while loop.
> The first time through, it will not work :)
>   Thanks,
>     Matt
>> On Fri, Sep 11, 2020 at 2:07 PM Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Fri, Sep 11, 2020 at 3:56 PM Zhuo Chen <chenzhuotj at gmail.com> wrote:
>>>> Hi Matthew,
>>>> Yes, if use
>>>> call KSPSetType(ksp,KSPGMRES,ierr);CHKERRQ(ierr)
>>>> call KSPSetFromOptions(ksp,ierr);CHKERRQ(ierr)
>>>> call
>>>> PetscOptionsSetValue(PETSC_NULL_OPTIONS,'-ksp_gmres_modifiedgramschmidt','1',ierr);CHKERRQ(ierr)
>>>> call
>>>> PetscOptionsSetValue(PETSC_NULL_OPTIONS,'-ksp_view','',ierr);CHKERRQ(ierr)
>>> Are you running in a loop?
>>>   Thanks,
>>>      Matt
>>>> to see if the modified Gram-Schmidt process is actually active. The
>>>> output is
>>>>   type: gmres
>>>>   tolerances:  relative=1e-11, absolute=1e-50, divergence=10000.
>>>> I think that means calling PetscOptionsSetValue()
>>>> after KSPSetFromOptions() works. Correct me if I am wrong.
>>>> Best.
>>>> On Fri, Sep 11, 2020 at 1:31 PM Matthew Knepley <knepley at gmail.com>
>>>> wrote:
>>>>> On Fri, Sep 11, 2020 at 3:05 PM Zhuo Chen <chenzhuotj at gmail.com>
>>>>> wrote:
>>>>>> Hi Hong,
>>>>>> Thank you very much for the plan.
>>>>>> Though it may be obvious to many Petsc gurus. I would like to
>>>>>> summarize my solution to activate the modified Gram-Schmidt
>>>>>> orthogonalization process in Fortran now. It may help some new Petsc users.
>>>>>> Option 1: append the -ksp_gmres_modifiedgramschmidt at runtime, the
>>>>>> code would look like
>>>>>> and to run the program, use
>>>>>> mpiexec -np 2 ./run -ksp_gmres_modifiedgramschmidt
>>>>>> Option 2: use PetscOptionsSetValue()
>>>>>> call
>>>>> Does it work if you call SetValue() after SetFromOptions()? I would
>>>>> not think that would work.
>>>>>   Thanks,
>>>>>      Matt
>>>>>> mpiexec -np 2 ./run
>>>>>> Best.
>>>>>> On Fri, Sep 11, 2020 at 9:05 AM Zhang, Hong <hzhang at mcs.anl.gov>
>>>>>> wrote:
>>>>>>> Zhuo,
>>>>>>> I'll try to get it done after the incoming release. My hands are
>>>>>>> full with more urgent tasks at moment. I'll let you know after I'm done.
>>>>>>> Thanks for your patience.
>>>>>>> Hong
>>>>>>> *From:* Zhuo Chen <chenzhuotj at gmail.com>
>>>>>>> *Sent:* Thursday, September 10, 2020 8:41 PM
>>>>>>> *To:* Zhang, Hong <hzhang at mcs.anl.gov>
>>>>>>> *Cc:* petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
>>>>>>> *Subject:* Re: [petsc-users] How to activate the modified
>>>>>>> Hi Hong,
>>>>>>> According to that very old thread, KSPGMRESSetOrthogonalization was
>>>>>>> not implemented in Fortran. I did as you suggested and the compiler will
>>>>>>> tell me
>>>>>>> undefined reference to `kspgmressetorthogonalization_'
>>>>>>> I think I will use the -ksp_gmres_modifiedgramschmidt method. Thank
>>>>>>> you so much!
>>>>>>> On Thu, Sep 10, 2020 at 7:32 PM Zhang, Hong <hzhang at mcs.anl.gov>
>>>>>>> wrote:
>>>>>>> Zhuo,
>>>>>>> Call
>>>>>>> KSPSetType(ksp,KSPGMRES);
>>>>>>> KSPGMRESSetOrthogonalization(ksp,KSPGMRESModifiedGramSchmidtOrthogonalization);
>>>>>>> Hong
>>>>>>> *Sent:* Thursday, September 10, 2020 8:17 PM
>>>>>>> Hi Hong,
>>>>>>> Thank you very much for your help.
>>>>>>> It seems that if I simply append -ksp_gmres_modifiedgramschmidt the
>>>>>>> warning goes away. However
>>>>>>> KSPGMRESSetOrthogonalization(ksp,KSPGMRESModifiedGramSchmidtOrthogonalization,ierr)
>>>>>>> has another issue.
>>>>>>> Error: Symbol ‘kspgmresmodifiedgramschmidtorthogonalization’ at (1)
>>>>>>> has no IMPLICIT type
>>>>>>> Is it because the argument is too long? I am using gcc 8.4.0 instead
>>>>>>> of ifort
>>>>>>> On Thu, Sep 10, 2020 at 7:08 PM Zhang, Hong <hzhang at mcs.anl.gov>
>>>>>>> wrote:
>>>>>>> Zhuo,
>>>>>>> Run your code with option '-ksp_gmres_modifiedgramschmidt'. For
>>>>>>> example,
>>>>>>> petsc/src/ksp/ksp/tutorials
>>>>>>> mpiexec -n 2 ./ex2 -ksp_view -ksp_gmres_modifiedgramschmidt
>>>>>>> KSP Object: 2 MPI processes
>>>>>>>   type: gmres
>>>>>>>   tolerances:  relative=0.000138889, absolute=1e-50,
>>>>>>> divergence=10000.
>>>>>>> PC Object: 2 MPI processes
>>>>>>>   type: bjacobi
>>>>>>> You can
>>>>>>> call KSPGMRESSetOrthogonalization(ksp,KSPGMRESModifiedGramSchmidtOrthogonalization)
>>>>>>> in your program.
>>>>>>> Hong
>>>>>>> *From:* petsc-users <petsc-users-bounces at mcs.anl.gov> on behalf of
>>>>>>> *Sent:* Thursday, September 10, 2020 7:52 PM
>>>>>>> *To:* petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
>>>>>>> *Subject:* [petsc-users] How to activate the modified Gram-Schmidt
>>>>>>> Dear Petsc users,
>>>>>>> I found an ancient thread discussing this problem.
>>>>>>> https://lists.mcs.anl.gov/pipermail/petsc-users/2011-October/010607.html
>>>>>>> However, when I add
>>>>>>> call
>>>>>>> the program will tell me
>>>>>>> WARNING! There are options you set that were not used!
>>>>>>> WARNING! could be spelling mistake, etc!
>>>>>>> There is one unused database option. It is:
>>>>>>> Option left: name:-ksp_gmres_modifiedgramschmidt value: 1
>>>>>>> I would like to know the most correct way to activate the modified
>>>>>>> Gram-Schmidt orthogonalization process in Fortran. Thank you very much!
>>>>>>> Best regards.
>>>>>>> Zhuo Chen
>>>>>>> Department of Physics
>>>>>>> University of Alberta
>>>>>>> Edmonton Alberta, Canada T6G 2E1
>>>>>>> http://www.pas.rochester.edu/~zchen25/
>>>>>>> Zhuo Chen
>>>>>>> Zhuo Chen
>>>>>> Zhuo Chen
>>>>> What most experimenters take for granted before they begin their
>>>>> experiments is infinitely more interesting than any results to which their
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>>> Zhuo Chen
>>> experiments lead.
>>> -- Norbert Wiener
>> Zhuo Chen
> experiments lead.
> -- Norbert Wiener
Zhuo Chen
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200911/3364972e/attachment-0001.html>
