[petsc-users] How to activate the modified Gram-Schmidt orthogonalization process in Fortran?
Zhang, Hong
hzhang at mcs.anl.gov
Fri Sep 11 10:05:37 CDT 2020
Zhuo,
I'll try to get it done after the incoming release. My hands are full with more urgent tasks at moment. I'll let you know after I'm done.
Thanks for your patience.
Hong
Sent: Thursday, September 10, 2020 8:41 PM
To: Zhang, Hong <hzhang at mcs.anl.gov>
Cc: petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
Subject: Re: [petsc-users] How to activate the modified Gram-Schmidt orthogonalization process in Fortran?
Hi Hong,
According to that very old thread, KSPGMRESSetOrthogonalization was not implemented in Fortran. I did as you suggested and the compiler will tell me
undefined reference to `kspgmressetorthogonalization_'
I think I will use the -ksp_gmres_modifiedgramschmidt method. Thank you so much!
On Thu, Sep 10, 2020 at 7:32 PM Zhang, Hong <hzhang at mcs.anl.gov<mailto:hzhang at mcs.anl.gov>> wrote:
Zhuo,
Call
KSPSetType(ksp,KSPGMRES);
KSPGMRESSetOrthogonalization(ksp,KSPGMRESModifiedGramSchmidtOrthogonalization);
Hong
From: Zhuo Chen <chenzhuotj at gmail.com<mailto:chenzhuotj at gmail.com>>
Sent: Thursday, September 10, 2020 8:17 PM
To: Zhang, Hong <hzhang at mcs.anl.gov<mailto:hzhang at mcs.anl.gov>>
Cc: petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov> <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>>
Hi Hong,
Thank you very much for your help.
It seems that if I simply append -ksp_gmres_modifiedgramschmidt the warning goes away. However KSPGMRESSetOrthogonalization(ksp,KSPGMRESModifiedGramSchmidtOrthogonalization,ierr) has another issue.
Error: Symbol ‘kspgmresmodifiedgramschmidtorthogonalization’ at (1) has no IMPLICIT type
Is it because the argument is too long? I am using gcc 8.4.0 instead of ifort
On Thu, Sep 10, 2020 at 7:08 PM Zhang, Hong <hzhang at mcs.anl.gov<mailto:hzhang at mcs.anl.gov>> wrote:
Zhuo,
Run your code with option '-ksp_gmres_modifiedgramschmidt'. For example,
petsc/src/ksp/ksp/tutorials
mpiexec -n 2 ./ex2 -ksp_view -ksp_gmres_modifiedgramschmidt
KSP Object: 2 MPI processes
type: gmres
restart=30, using Modified Gram-Schmidt Orthogonalization
happy breakdown tolerance 1e-30
maximum iterations=10000, initial guess is zero
tolerances: relative=0.000138889, absolute=1e-50, divergence=10000.
left preconditioning
using PRECONDITIONED norm type for convergence test
PC Object: 2 MPI processes
type: bjacobi
You can call KSPGMRESSetOrthogonalization(ksp,KSPGMRESModifiedGramSchmidtOrthogonalization) in your program.
Hong
From: petsc-users <petsc-users-bounces at mcs.anl.gov<mailto:petsc-users-bounces at mcs.anl.gov>> on behalf of Zhuo Chen <chenzhuotj at gmail.com<mailto:chenzhuotj at gmail.com>>
Sent: Thursday, September 10, 2020 7:52 PM
To: petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov> <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>>
Subject: [petsc-users] How to activate the modified Gram-Schmidt orthogonalization process in Fortran?
Dear Petsc users,
I found an ancient thread discussing this problem.
https://lists.mcs.anl.gov/pipermail/petsc-users/2011-October/010607.html
However, when I add
call KSPSetType(ksp,KSPGMRES,ierr);CHKERRQ(ierr)
call PetscOptionsSetValue(PETSC_NULL_OPTIONS,'-ksp_gmres_modifiedgramschmidt','1',ierr);CHKERRQ(ierr)
the program will tell me
WARNING! There are options you set that were not used!
WARNING! could be spelling mistake, etc!
There is one unused database option. It is:
Option left: name:-ksp_gmres_modifiedgramschmidt value: 1
I would like to know the most correct way to activate the modified Gram-Schmidt orthogonalization process in Fortran. Thank you very much!
Best regards.
Zhuo Chen
Department of Physics
University of Alberta
Edmonton Alberta, Canada T6G 2E1
http://www.pas.rochester.edu/~zchen25/
Zhuo Chen
Zhuo Chen
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200911/c40303e4/attachment.html>
