[petsc-users] How to activate the modified Gram-Schmidt orthogonalization process in Fortran?
Klaij, Christiaan C.Klaij at marin.nl
Fri Sep 11 07:50:26 CDT 2020
Make me feel ancient. Would be nice to have the fortran binding though...
Chris
> Message: 1
> Date: Thu, 10 Sep 2020 19:41:30 -0600
> From: Zhuo Chen <chenzhuotj at gmail.com>
> To: "Zhang, Hong" <hzhang at mcs.anl.gov>
> Cc: "petsc-users at mcs.anl.gov" <petsc-users at mcs.anl.gov>
> Subject: Re: [petsc-users] How to activate the modified Gram-Schmidt
> Message-ID:
>         <CAHjeDn8HmgxttujK6YP0qfgPcmQMbVNa0UTFN4Wd_Au-0UjDAg at mail.gmail.com>
> Content-Type: text/plain; charset="utf-8"
> Hi Hong,
> According to that very old thread, KSPGMRESSetOrthogonalization was not
> implemented in Fortran. I did as you suggested and the compiler will tell
> me
> undefined reference to `kspgmressetorthogonalization_'
> I think I will use the -ksp_gmres_modifiedgramschmidt method. Thank you so
> much!
dr. ir. Christiaan Klaij  | Senior Researcher | Research & Development
MARIN | T +31 317 49 33 44 | mailto:C.Klaij at marin.nl | http://www.marin.nl
> On Thu, Sep 10, 2020 at 7:32 PM Zhang, Hong <hzhang at mcs.anl.gov> wrote:
> > Zhuo,
> > Call
> > KSPSetType(ksp,KSPGMRES);
> > KSPGMRESSetOrthogonalization(ksp,KSPGMRESModifiedGramSchmidtOrthogonalization);
> > Hong
> > *From:* Zhuo Chen <chenzhuotj at gmail.com>
> > *Sent:* Thursday, September 10, 2020 8:17 PM
> > *To:* Zhang, Hong <hzhang at mcs.anl.gov>
> > *Cc:* petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
> > *Subject:* Re: [petsc-users] How to activate the modified Gram-Schmidt
> > Hi Hong,
> > Thank you very much for your help.
> > It seems that if I simply append -ksp_gmres_modifiedgramschmidt the
> > warning goes away. However
> > KSPGMRESSetOrthogonalization(ksp,KSPGMRESModifiedGramSchmidtOrthogonalization,ierr)
> > has another issue.
> > Error: Symbol ?kspgmresmodifiedgramschmidtorthogonalization? at (1) has no
> > IMPLICIT type
> > Is it because the argument is too long? I am using gcc 8.4.0 instead of
> > ifort
> > On Thu, Sep 10, 2020 at 7:08 PM Zhang, Hong <hzhang at mcs.anl.gov> wrote:
> > Zhuo,
> > Run your code with option '-ksp_gmres_modifiedgramschmidt'. For example,
> > petsc/src/ksp/ksp/tutorials
> > mpiexec -n 2 ./ex2 -ksp_view -ksp_gmres_modifiedgramschmidt
> > KSP Object: 2 MPI processes
> >   type: gmres
> >     restart=30, using Modified Gram-Schmidt Orthogonalization
> >     happy breakdown tolerance 1e-30
> >   maximum iterations=10000, initial guess is zero
> >   tolerances:  relative=0.000138889, absolute=1e-50, divergence=10000.
> >   left preconditioning
> >   using PRECONDITIONED norm type for convergence test
> > PC Object: 2 MPI processes
> >   type: bjacobi
> > You can
> > call KSPGMRESSetOrthogonalization(ksp,KSPGMRESModifiedGramSchmidtOrthogonalization)
> > in your program.
> > Hong
> > *From:* petsc-users <petsc-users-bounces at mcs.anl.gov> on behalf of Zhuo
> > *Sent:* Thursday, September 10, 2020 7:52 PM
> > *To:* petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
> > *Subject:* [petsc-users] How to activate the modified Gram-Schmidt
> > Dear Petsc users,
> > I found an ancient thread discussing this problem.
> > https://lists.mcs.anl.gov/pipermail/petsc-users/2011-October/010607.html
> > However, when I add
> > call KSPSetType(ksp,KSPGMRES,ierr);CHKERRQ(ierr)
> > call
> > PetscOptionsSetValue(PETSC_NULL_OPTIONS,'-ksp_gmres_modifiedgramschmidt','1',ierr);CHKERRQ(ierr)
> > the program will tell me
> > WARNING! There are options you set that were not used!
> > WARNING! could be spelling mistake, etc!
> > There is one unused database option. It is:
> > Option left: name:-ksp_gmres_modifiedgramschmidt value: 1
> > I would like to know the most correct way to activate the modified
> > Gram-Schmidt orthogonalization process in Fortran. Thank you very much!
> > Best regards.
