[petsc-users] How to activate the modified Gram-Schmidt orthogonalization process in Fortran?
Zhuo Chen
chenzhuotj at gmail.com
Thu Sep 10 19:52:17 CDT 2020
Dear Petsc users,
I found an ancient thread discussing this problem.
https://lists.mcs.anl.gov/pipermail/petsc-users/2011-October/010607.html
However, when I add
call KSPSetType(ksp,KSPGMRES,ierr);CHKERRQ(ierr)
call
PetscOptionsSetValue(PETSC_NULL_OPTIONS,'-ksp_gmres_modifiedgramschmidt','1',ierr);CHKERRQ(ierr)
the program will tell me
WARNING! There are options you set that were not used!
WARNING! could be spelling mistake, etc!
There is one unused database option. It is:
Option left: name:-ksp_gmres_modifiedgramschmidt value: 1
I would like to know the most correct way to activate the modified
Gram-Schmidt orthogonalization process in Fortran. Thank you very much!
Best regards.
Zhuo Chen
Department of Physics
University of Alberta
Edmonton Alberta, Canada T6G 2E1
http://www.pas.rochester.edu/~zchen25/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200910/586d31b6/attachment.html>
