[petsc-users] Converting a Parallel(MPI) Matrix to a Sequential Matrix
Anthony Dowling
dowlinah at clarkson.edu
Mon Sep 7 10:16:54 CDT 2020
Thank you for your help, Matthew.
With those methods, will I be able to copy the contents of the created
serial matrices back to a parallel matrix if needed? If so, what is a good
way to do that?
Anthony Dowling
On Mon, Sep 7, 2020 at 11:12 AM Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Sep 7, 2020 at 11:00 AM Anthony Dowling <dowlinah at clarkson.edu>
> wrote:
>> Hello all,
>> Is there a method to convert a parallel(MPI) dense matrix to a sequential
>> dense matrix? Also to do the same in reverse? The code I am using needs to
>> be able to convert a float** matrix to a Petsc matrix, and then later
>> convert that Petsc matrix between MPI dense and sequential dense. How might
>> this be achieved? The code seems to be converting float** matrices to Petsc
>> properly, but I am unable to find a method to convert between MPI and
>> sequential matrices.
> If you want the serial matrix everywhere, this is easy:
> https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatCreateRedundantMatrix.html
> If you want it just on 1 process, you can use:
> https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatCreateSubMatrices.html
> Thanks,
> Matt
>> Thanks in advance,
>> Anthony Dowling
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200907/878cb541/attachment.html>
