[petsc-users] VTK format?
Jed Brown
jed at jedbrown.org
Thu Sep 3 10:47:40 CDT 2020
I'd have deleted the legacy vtk many years ago, but Matt says he uses it.
On Thu, Sep 3, 2020, at 9:45 AM, Barry Smith wrote:
> Shouldn't this, "just work". PETSc should not be dumping unreadable garbage into any files, does the broken PETSc code need to be removed, or error out until it can be fixed?
> Barry
>> On Sep 3, 2020, at 9:53 AM, Jed Brown <jed at jedbrown.org> wrote:
>> Use the xml format (not the legacy format) by naming your file.vtu instead of file.vtk
>> On Thu, Sep 3, 2020, at 8:17 AM, Berend van Wachem wrote:
>>> Dear PETSc,
>>> What is the best way to write data from a DMPLEX vector to file, so it
>>> can be viewed with paraview?
>>> I've found that the standard VTK format works for a serial job, but if
>>> there is more than 1 processor, the geometry data gets messed up.
>>> I've attached a small working example for a cylinder and the visualised
>>> geometry with paraview for 1 processors and 4 processors.
>>> Any pointers or "best practice" very much appreciated.
>>> Best regards,
>>> Berend.
>>> *Attachments:*
>>> * visualizemesh.c
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200903/b1772866/attachment-0001.html>
