[petsc-users] error: invalid types ‘PetscScalar* {aka double*}[PetscScalar {aka double}]’ for array subscript
Matthew Knepley
knepley at gmail.com
Tue Sep 1 06:03:57 CDT 2020
On Tue, Sep 1, 2020 at 1:16 AM Smit Thijs <thijs.smit at hest.ethz.ch> wrote:
> Hi Matt,
> Thanks for your replay.
> I am working with a structured grid and in this case the content of the
> vector to be mapped does not overlap between processes. My understanding
> (although I am a beginner with PETSc) is that I don’t have to use IS in
> that case?
> ierr = DMCreateGlobalVector(da_elem, &xPhys);
> CHKERRQ(ierr);
> Is there a way to solve this problem without using IS?
What I say below is that you cannot index a C array with a real number. You
have to do it with an integer. A PETSc IS is a list of integers, which is
why I suggested that.
Matt
> Best, Thijs
> *From:* Matthew Knepley <knepley at gmail.com>
> *Sent:* 21 August 2020 18:20
> *To:* Smit Thijs <thijs.smit at hest.ethz.ch>
> *Cc:* petsc-users at mcs.anl.gov
> *Subject:* Re: [petsc-users] error: invalid types ‘PetscScalar* {aka
> On Fri, Aug 21, 2020 at 11:49 AM Smit Thijs <thijs.smit at hest.ethz.ch>
> wrote:
> Hi All,
> I am having the following error when I try to do a mapping with vectors
> and I can’t figure out how to solve this or what is going wrong:
> xpMMA[i] = xp[indicesMap[i]];
> Herewith two code snippets:
> // total number of elements on core
> PetscInt nel;
> VecGetLocalSize(xPhys, &nel);
> // create xPassive vector
> ierr = VecDuplicate(xPhys, &xPassive);
> CHKERRQ(ierr);
> // create mapping vector
> ierr = VecDuplicate(xPhys, &indicator);
> CHKERRQ(ierr);
> // index set for xPassive and indicator
> PetscScalar *xpPassive, *xpIndicator;
> ierr = VecGetArray(xPassive, &xpPassive);
> CHKERRQ(ierr);
> ierr = VecGetArray(indicator, &xpIndicator);
> CHKERRQ(ierr);
> // counters for total and active elements on this processor
> PetscInt tcount = 0; // total number of elements
> PetscInt acount = 0; // number of active elements
> PetscInt scount = 0; // number of solid elements
> PetscInt rcount = 0; // number of rigid element
> // loop over all elements and update xPassive from wrapper data
> // count number of active elements, acount
> // set indicator vector
> for (PetscInt el = 0; el < nel; el++) {
> if (data.xPassive_w.size() > 1) {
> xpPassive[el] = data.xPassive_w[el];
> tcount++;
> if (xpPassive[el] < 0) {
> xpIndicator[acount] = el;
> acount++;
> } else {
> xpPassive[el] = -1.0; // default, if no xPassive_w than all
> elements are active = -1.0
> // printing
> //PetscPrintf(PETSC_COMM_WORLD, "tcount: %i\n", tcount);
> //PetscPrintf(PETSC_COMM_WORLD, "acount: %i\n", acount);
> // Allreduce, get number of active elements over all processes
> // tmp number of var on proces
> // acount total number of var sumed
> PetscInt tmp = acount;
> acount = 0.0;
> MPI_Allreduce(&tmp, &(acount), 1, MPIU_INT, MPI_SUM, PETSC_COMM_WORLD);
> //// create xMMA vector
> VecCreateMPI(PETSC_COMM_WORLD, tmp, acount, &xMMA);
> // Pointers to the vectors
> PetscScalar *xp, *xpMMA, *indicesMap;
> Here you declare indicesMap as PetscScalar[]. You cannot index an array
> with this. I see that you
> want to store these indices in a Vec. You should use an IS instead.
> Thanks,
> Matt
> //PetscInt indicesMap;
> ierr = VecGetArray(MMAVector, &xpMMA);
> CHKERRQ(ierr);
> ierr = VecGetArray(elementVector, &xp);
> CHKERRQ(ierr);
> // Index set
> PetscInt nLocalVar;
> VecGetLocalSize(xMMA, &nLocalVar);
> // print number of var on pocessor
> PetscPrintf(PETSC_COMM_WORLD, "Local var: %i\n", nLocalVar);
> ierr = VecGetArray(indicator, &indicesMap);
> CHKERRQ(ierr);
> // Run through the indices
> for (PetscInt i = 0; i < nLocalVar; i++) {
> if (updateDirection > 0) {
> //PetscPrintf(PETSC_COMM_WORLD, "i: %i, xp[%i] = %f\n", i,
> indicesMap[i], xp[indicesMap[i]]);
> } else if (updateDirection < 0) {
> xp[indicesMap[i]] = xpMMA[i];
> // Restore
> ierr = VecRestoreArray(elementVector, &xp);
> CHKERRQ(ierr);
> ierr = VecRestoreArray(MMAVector, &xpMMA);
> CHKERRQ(ierr);
> ierr = VecRestoreArray(indicator, &indicesMap);
> CHKERRQ(ierr);
> PetscPrintf(PETSC_COMM_WORLD, "FINISHED UpdateVariables \n");
> The error message says that the type with which I try to index is wrong, I
> think. But VecGetArray only excepts scalars. Furthermore, the el variable
> is an int, but is seams like to turn out to be a scalar. Does anybody see
> how to proceed with this?
> Best regards,
> Thijs Smit
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200901/3ecb5bef/attachment-0001.html>
