[petsc-users] Quite different behaviours of PETSc solver on different clusters
Thu Oct 29 20:05:53 CDT 2020
On Thu, Oct 29, 2020 at 3:04 PM Su,D.S. Danyang <dsu at eoas.ubc.ca> wrote:
> Dear PETSc users,
> This is a question bother me for some time. I have the same code running
> on different clusters and both clusters have good speedup. However, I
> noticed some thing quite strange. On one cluster, the solver is quite
> stable in computing time while on another cluster, the solver is unstable
> in computing time. As shown in the figure below, the local calculation
> almost has no communication and the computing time in this part is quite
> stable. However, PETSc solver on Cluster B jumps quite a lot and the
> performance is not as good as Cluster A, even though the local calculation
> is a little better on Cluster B. There are some difference on hardware and
> PETSc configuration and optimization. Cluster A uses OpenMPI + GCC compiler
> and Cluster B uses MPICH + GCC compiler. The number of processors used is
> 128 on Cluster A and 120 on Cluster B. I also tested different number of
> processors but the problem is the same. Does anyone have any idea which
> part might cause this problem?
First question: Does the solver take more iterates when the time bumps up?
    Matt
> Thanks and regards,
> Danyang
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20201029/9c1cf548/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20201029/9c1cf548/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20201029/9c1cf548/attachment-0003.png>
