[petsc-users] Regarding changes in the 3.14 release
Wed Oct 28 20:08:39 CDT 2020
On Wed, Oct 28, 2020 at 8:57 PM Sajid Ali <sajidsyed2021 at u.northwestern.edu>
wrote:
> Hi Matt,
> Thanks for the clarification. The documentation
> <https://gitlab.com/petsc/petsc/-/blob/master/src/snes/interface/snes.c#L3304>
> for SNESSetLagPreconditioner states "If  -1 is used before the very first
> nonlinear solve the preconditioner is still built because there is no
> previous preconditioner to use" which was true prior to 3.14, is this
> statement no longer valid ?
Sounds like it is not. Barry?
> What is the difference between having -snes_lag_preconditioner -2 and
> having -snes_lag_preconditioner_persists true ?
Persists applies to multiple solves, whereas -2 only applies to the current
one.
     Matt
> PS :  The man pages for SNESSetLagJacobianPersists should perhaps not
> state the lag preconditioner options database keys and vice versa for
> clarity.
> Thank You,
> Sajid Ali | PhD Candidate
> Applied Physics
> Northwestern University
> s-sajid-ali.github.io
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20201028/b74a6489/attachment.html>
