[petsc-users] Blas undefined references when build an app linking to a shared library that is linked to a static Petsc library
    Barry Smith
    bsmith at petsc.dev
    Fri Oct 23 19:36:36 CDT 2020
  I found
http://icl.cs.utk.edu/lapack-forum/viewtopic.php?f=2&t=1730 <http://icl.cs.utk.edu/lapack-forum/viewtopic.php?f=2&t=1730>
but I do not understand it.
I am pretty sure PETSc is not providing in anyway even through its packages like fblaslapack blas_sgemv_x anyway I would focus on figuring out where those are coming from. Normal compilers won't need them. Do you use them?
  Good luck
   Barry
> On Oct 23, 2020, at 7:21 PM, Thuc Bui <bui at calcreek.com> wrote:
> Dear Petsc Users,
> I hope someone out there has already encountered the same linking problem and already figured this out, or has some idea how to resolve this issue. I have google searched but haven’t found any solution.
> I successfully ported Petsc 3.13.5 both as shared and static libraries in both Windows 10 (Visual Studio 2015, no Fortran) and Ubuntu 20.4 (gcc, g++. gfortran 9.3), and successfully run “make check” in all. I am also able to build my own shared libraries linked to either shared or static Petsc library in both platforms. I was also able to link and execute my application to either of these shared libraries in Windows. Unfortunately, I could only get my app to link and execute with the shared library linked to the shared Petsc library in Ubuntu, but not with the static Petsc library.
> On Ubuntu, below is how I build Petsc static library, which produces three libraries: libpetsc.a, libfblas.a and libflapack.a
> ./configure CFLAGS="-fPIC" CXXFLAGS="-fPIC" FFLAGS="-fPIC" -with-cc=gcc --with-cxx=g++ --with-fc=gfortran --with-openmp --with-debugging=0 --download-fblaslapack --with-mpi=0 --with-shared-libraries=0
> Below is the make output on how I build my shared library, cPoissons.so linking to the static Petsc. Please note that I have to use --allow-multiple-definition to override the redefinition errors in lapack and blas. I also use --whole-archive to make sure the shared library has all the required information from lapack and blas.
> gcc -fPIC -c -o gcc/matrixUtil.o matrixUtil.c
>                 -I/home/bbwannabe/Documents/Petsc/latest/include
>                 -I/home/bbwannabe/Documents/Petsc/latest/include/petsc/private
>                 -I/home/bbwannabe/Documents/Petsc/latest/gcc-x64SRelease/include
> gcc -fPIC -c -o gcc/PetscSolver.o PetscSolver.c
> gcc -fPIC -c -o gcc/LinearSystemSolver.o LinearSystemSolver.c
> gcc -fPIC -c -o gcc/cPoisson.o cPoisson.c
> gcc -fPIC -fopenmp -shared -o gcc/cPoissons.so gcc/matrixUtil.o gcc/PetscSolver.o gcc/LinearSystemSolver.o gcc/cPoisson.o
>                 -L/home/bbwannabe/Documents/Petsc/latest/gcc-x64SRelease/lib
>                 -Wl,--allow-multiple-definition
>                 -Wl,--whole-archive -lpetsc -lflapack -lfblas -Wl,--no-whole-archive
> However, when I build my app linking to the above shared library cPoissons.so. gfortran complains about undefined references, which seem to be from blas as shown below from the output of make. Has anyone seen this kind of linking problem before?
> Many thanks for your help.
> Thuc Bui
> Senior R&D Engineer
> Calabazas Creek Research, Inc.
> (650) 948-5361 (Office)
> gfortran -fPIC -o sPoisson3D Poisson3D.f -L/home/bbwannabe/Documents/Nemesis/cPoisson/gcc -l:cPoissons.so
> /usr/bin/ld: /home/bbwannabe/Documents/Nemesis/cPoisson/gcc/cPoissons.so: undefined reference to `blas_sgemv_x_'
> /usr/bin/ld: /home/bbwannabe/Documents/Nemesis/cPoisson/gcc/cPoissons.so: undefined reference to `blas_zgemv_x_'
> /usr/bin/ld: /home/bbwannabe/Documents/Nemesis/cPoisson/gcc/cPoissons.so: undefined reference to `blas_cgbmv_x_'
> /usr/bin/ld: /home/bbwannabe/Documents/Nemesis/cPoisson/gcc/cPoissons.so: undefined reference to `blas_cgbmv2_x_'
> /usr/bin/ld: /home/bbwannabe/Documents/Nemesis/cPoisson/gcc/cPoissons.so: undefined reference to `blas_chemv2_x_'
> /usr/bin/ld: /home/bbwannabe/Documents/Nemesis/cPoisson/gcc/cPoissons.so: undefined reference to `blas_csymv2_x_'
> /usr/bin/ld: /home/bbwannabe/Documents/Nemesis/cPoisson/gcc/cPoissons.so: undefined reference to `blas_sgbmv_x_'
> /usr/bin/ld: /home/bbwannabe/Documents/Nemesis/cPoisson/gcc/cPoissons.so: undefined reference to `blas_dgemv_x_'
> /usr/bin/ld: /home/bbwannabe/Documents/Nemesis/cPoisson/gcc/cPoissons.so: undefined reference to `blas_zsymv_x_'
> /usr/bin/ld: /home/bbwannabe/Documents/Nemesis/cPoisson/gcc/cPoissons.so: undefined reference to `blas_csymv_x_'
> /usr/bin/ld: /home/bbwannabe/Documents/Nemesis/cPoisson/gcc/cPoissons.so: undefined reference to `blas_ssymv2_x_'
> /usr/bin/ld: /home/bbwannabe/Documents/Nemesis/cPoisson/gcc/cPoissons.so: undefined reference to `blas_ssymv_x_'
> /usr/bin/ld: /home/bbwannabe/Documents/Nemesis/cPoisson/gcc/cPoissons.so: undefined reference to `blas_zgemv2_x_'
> /usr/bin/ld: /home/bbwannabe/Documents/Nemesis/cPoisson/gcc/cPoissons.so: undefined reference to `blas_dsymv2_x_'
> /usr/bin/ld: /home/bbwannabe/Documents/Nemesis/cPoisson/gcc/cPoissons.so: undefined reference to `blas_zhemv_x_'
> /usr/bin/ld: /home/bbwannabe/Documents/Nemesis/cPoisson/gcc/cPoissons.so: undefined reference to `blas_zgbmv2_x_'
> /usr/bin/ld: /home/bbwannabe/Documents/Nemesis/cPoisson/gcc/cPoissons.so: undefined reference to `blas_sgemv2_x_'
> /usr/bin/ld: /home/bbwannabe/Documents/Nemesis/cPoisson/gcc/cPoissons.so: undefined reference to `blas_chemv_x_'
> /usr/bin/ld: /home/bbwannabe/Documents/Nemesis/cPoisson/gcc/cPoissons.so: undefined reference to `blas_dgemv2_x_'
> /usr/bin/ld: /home/bbwannabe/Documents/Nemesis/cPoisson/gcc/cPoissons.so: undefined reference to `blas_cgemv2_x_'
> /usr/bin/ld: /home/bbwannabe/Documents/Nemesis/cPoisson/gcc/cPoissons.so: undefined reference to `blas_sgbmv2_x_'
> /usr/bin/ld: /home/bbwannabe/Documents/Nemesis/cPoisson/gcc/cPoissons.so: undefined reference to `blas_zgbmv_x_'
> /usr/bin/ld: /home/bbwannabe/Documents/Nemesis/cPoisson/gcc/cPoissons.so: undefined reference to `blas_dgbmv_x_'
> /usr/bin/ld: /home/bbwannabe/Documents/Nemesis/cPoisson/gcc/cPoissons.so: undefined reference to `blas_zhemv2_x_'
> /usr/bin/ld: /home/bbwannabe/Documents/Nemesis/cPoisson/gcc/cPoissons.so: undefined reference to `blas_zsymv2_x_'
> /usr/bin/ld: /home/bbwannabe/Documents/Nemesis/cPoisson/gcc/cPoissons.so: undefined reference to `blas_dsymv_x_'
> /usr/bin/ld: /home/bbwannabe/Documents/Nemesis/cPoisson/gcc/cPoissons.so: undefined reference to `blas_dgbmv2_x_'
> /usr/bin/ld: /home/bbwannabe/Documents/Nemesis/cPoisson/gcc/cPoissons.so: undefined reference to `blas_cgemv_x_'
> collect2: error: ld returned 1 exit status
> make: *** [makefile:6: sPoisson3D] Error 1
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20201023/b085b182/attachment.html>
