[petsc-users] Enhancing MatScale computing time
Barry Smith
bsmith at petsc.dev
Thu Oct 22 16:03:11 CDT 2020
Yes, you are correct I missed that part of the run
As you can see below MatScale calls only BLAS dscal() there is really no way to make that go faster.
How big is the matrix.
What are you doing with the matrix after you scale it? The only way to improve the time is to find some way to scale it less often.
It is curious that VecScale has a much higher flop rate when it has the same code see below. Unless the matrices are tiny I would expect similar flop rates.
Barry
PetscErrorCode MatScale_SeqAIJ(Mat inA,PetscScalar alpha)
Mat_SeqAIJ *a = (Mat_SeqAIJ*)inA->data;
PetscScalar oalpha = alpha;
PetscErrorCode ierr;
PetscBLASInt one = 1,bnz;
PetscFunctionBegin;
ierr = PetscBLASIntCast(a->nz,&bnz);CHKERRQ(ierr);
PetscStackCallBLAS("BLASscal",BLASscal_(&bnz,&oalpha,a->a,&one));
ierr = PetscLogFlops(a->nz);CHKERRQ(ierr);
ierr = MatSeqAIJInvalidateDiagonal(inA);CHKERRQ(ierr);
#if defined(PETSC_HAVE_DEVICE)
if (inA->offloadmask != PETSC_OFFLOAD_UNALLOCATED) inA->offloadmask = PETSC_OFFLOAD_CPU;
#endif
PetscFunctionReturn(0);
PetscErrorCode VecScale_Seq(Vec xin, PetscScalar alpha)
PetscBLASInt one = 1,bn;
PetscFunctionBegin;
ierr = PetscBLASIntCast(xin->map->n,&bn);CHKERRQ(ierr);
if (alpha == (PetscScalar)0.0) {
ierr = VecSet_Seq(xin,alpha);CHKERRQ(ierr);
} else if (alpha != (PetscScalar)1.0) {
PetscScalar a = alpha,*xarray;
ierr = VecGetArray(xin,&xarray);CHKERRQ(ierr);
PetscStackCallBLAS("BLASscal",BLASscal_(&bn,&a,xarray,&one));
ierr = VecRestoreArray(xin,&xarray);CHKERRQ(ierr);
ierr = PetscLogFlops(xin->map->n);CHKERRQ(ierr);
> On Oct 22, 2020, at 3:02 PM, Antoine Côté <Antoine.Cote3 at USherbrooke.ca> wrote:
> Hi,
> See attached files for both outputs. Tell me if you need any clarification. It was run with a DMDA of 33x17x17 nodes (creating 32x16x16=8192 elements). With 3 dof per nodes, problem has a total of 28611 dof.
> Note : Stage "Stiff_Adj" is the part of the code modifying Mat K. PetscLogStagePush/Pop was used.
> Regards,
> Antoine
> De : Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>>
> Envoyé : 22 octobre 2020 15:35
> À : Antoine Côté <Antoine.Cote3 at USherbrooke.ca <mailto:Antoine.Cote3 at USherbrooke.ca>>
> Cc : petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov> <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>>
> Objet : Re: [petsc-users] Enhancing MatScale computing time
> On Thu, Oct 22, 2020 at 3:23 PM Antoine Côté <Antoine.Cote3 at usherbrooke.ca <mailto:Antoine.Cote3 at usherbrooke.ca>> wrote:
> Hi,
> I'm working with a 3D DMDA, with 3 dof per "node", used to create a sparse matrix Mat K. The Mat is modified repeatedly by the program, using the commands (in that order) :
> MatZeroEntries(K)
> In a for loop : MatSetValuesLocal(K, 24, irow, 24, icol, vals, ADD_VALUES)
> MatAssemblyBegin(K, MAT_FINAL_ASSEMBLY)
> MatAssemblyEnd(K, MAT_FINAL_ASSEMBLY)
> MatDiagonalScale(K, vec1, vec1)
> MatDiagonalSet(K, vec2, ADD_VALUES)
> Computing time seems high and I would like to improve it. Running tests with "-log_view" tells me that MatScale() is the bottle neck (50% of total computing time) . From manual pages, I've tried a few tweaks :
> DMSetMatType(da, MATMPIBAIJ) : "For problems with multiple degrees of freedom per node, ... BAIJ can significantly enhance performance", Chapter 14.2.4
> Used MatMissingDiagonal() to confirm there is no missing diagonal entries : "If the matrix Y is missing some diagonal entries this routine can be very slow", MatDiagonalSet() manual
> Tried MatSetOption()
> MAT_NEW_NONZERO_LOCATIONS == PETSC_FALSE : to increase assembly efficiency
> MAT_NEW_NONZERO_LOCATION_ERR == PETSC_TRUE : "When true, assembly processes have one less global reduction"
> MAT_NEW_NONZERO_ALLOCATION_ERR == PETSC_TRUE : "When true, assembly processes have one less global reduction"
> MAT_USE_HASH_TABLE == PETSC_TRUE : "Improve the searches during matrix assembly"
> According to "-log_view", assembly is fast (0% of total time), and the use of a DMDA makes me believe preallocation isn't the cause of performance issue.
> I would like to know how could I improve MatScale(). What are the best practices (during allocation, when defining Vecs and Mats, the DMDA, etc.)? Instead of MatDiagonalScale(), should I use another command to obtain the same result faster?
> Something is definitely strange. Can you please send the output of
> -log_view -info :mat
> Thanks,
> Matt
> Thank you very much!
> Antoine Côté
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <https://can01.safelinks.protection.outlook.com/?url=http:%2F%2Fwww.cse.buffalo.edu%2F~knepley%2F&data=04%7C01%7CAntoine.Cote3%40usherbrooke.ca%7C6b823852b3964170f52908d876c1bb0b%7C3a5a8744593545f99423b32c3a5de082%7C0%7C0%7C637389921724846720%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=w7%2Fc%2BSzAfTa02gxTS8VbB%2FVwIPpaKw%2F%2BeiiX4K9gd1k%3D&reserved=0>
> <LogView.out><mat.0>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20201022/0f8c230f/attachment.html>
