[petsc-users] Enhancing MatScale computing time
Antoine Côté Antoine.Cote3 at USherbrooke.ca
Thu Oct 22 15:02:00 CDT 2020
See attached files for both outputs. Tell me if you need any clarification. It was run with a DMDA of 33x17x17 nodes (creating 32x16x16=8192 elements). With 3 dof per nodes, problem has a total of 28611 dof.
Note : Stage "Stiff_Adj" is the part of the code modifying Mat K. PetscLogStagePush/Pop was used.
Antoine
De : Matthew Knepley <knepley at gmail.com>
Envoyé : 22 octobre 2020 15:35
À : Antoine Côté <Antoine.Cote3 at USherbrooke.ca>
Cc : petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
Objet : Re: [petsc-users] Enhancing MatScale computing time
On Thu, Oct 22, 2020 at 3:23 PM Antoine Côté <Antoine.Cote3 at usherbrooke.ca<mailto:Antoine.Cote3 at usherbrooke.ca>> wrote:
I'm working with a 3D DMDA, with 3 dof per "node", used to create a sparse matrix Mat K. The Mat is modified repeatedly by the program, using the commands (in that order) :
MatZeroEntries(K)
In a for loop : MatSetValuesLocal(K, 24, irow, 24, icol, vals, ADD_VALUES)
MatAssemblyBegin(K, MAT_FINAL_ASSEMBLY)
MatAssemblyEnd(K, MAT_FINAL_ASSEMBLY)
MatDiagonalScale(K, vec1, vec1)
MatDiagonalSet(K, vec2, ADD_VALUES)
Computing time seems high and I would like to improve it. Running tests with "-log_view" tells me that MatScale() is the bottle neck (50% of total computing time) . From manual pages, I've tried a few tweaks :
  *   DMSetMatType(da, MATMPIBAIJ) : "For problems with multiple degrees of freedom per node, ... BAIJ can significantly enhance performance", Chapter 14.2.4
  *   Used MatMissingDiagonal() to confirm there is no missing diagonal entries : "If the matrix Y is missing some diagonal entries this routine can be very slow", MatDiagonalSet() manual
  *   Tried MatSetOption()
     *   MAT_NEW_NONZERO_LOCATIONS == PETSC_FALSE : to increase assembly efficiency
     *   MAT_NEW_NONZERO_LOCATION_ERR == PETSC_TRUE : "When true, assembly processes have one less global reduction"
     *   MAT_NEW_NONZERO_ALLOCATION_ERR == PETSC_TRUE : "When true, assembly processes have one less global reduction"
     *   MAT_USE_HASH_TABLE == PETSC_TRUE : "Improve the searches during matrix assembly"
According to "-log_view", assembly is fast (0% of total time), and the use of a DMDA makes me believe preallocation isn't the cause of performance issue.
I would like to know how could I improve MatScale(). What are the best practices (during allocation, when defining Vecs and Mats, the DMDA, etc.)? Instead of MatDiagonalScale(), should I use another command to obtain the same result faster?
Something is definitely strange. Can you please send the output of
  -log_view -info :mat
     Matt
Thank you very much!
Antoine Côté
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/<https://can01.safelinks.protection.outlook.com/?url=http:%2F%2Fwww.cse.buffalo.edu%2F~knepley%2F&data=04%7C01%7CAntoine.Cote3%40usherbrooke.ca%7C6b823852b3964170f52908d876c1bb0b%7C3a5a8744593545f99423b32c3a5de082%7C0%7C0%7C637389921724846720%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=w7%2Fc%2BSzAfTa02gxTS8VbB%2FVwIPpaKw%2F%2BeiiX4K9gd1k%3D&reserved=0>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20201022/4836e24b/attachment-0001.html>
Desc: LogView.out
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20201022/4836e24b/attachment-0002.obj>
Desc: mat.0
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20201022/4836e24b/attachment-0003.obj>
