[petsc-users] FPE when trying to find the condition number
baikadi pranay pranayreddy865 at gmail.com
Thu Oct 22 14:12:51 CDT 2020
Hello,
I am trying to find the condition number of the A matrix for a linear
system I am solving. I have used the following commands.
*./a.out -ksp_monitor_singular_value -ksp_type gmres -ksp_gmres_restart
1000 -pc_type none*However, the execution comes to a halt after a few
iterations with the following error.
[0]PETSC ERROR:
[0]PETSC ERROR: Caught signal number 8 FPE: Floating Point
Exception,probably divide by zero
[0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[0]PETSC ERROR: or see
http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
[0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X
to find memory corruption errors
[0]PETSC ERROR: likely location of problem given in stack below
[0]PETSC ERROR: ---------------------  Stack Frames
[0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[0]PETSC ERROR:       INSTEAD the line number of the start of the function
[0]PETSC ERROR:       is given.
[0]PETSC ERROR: [0] LAPACKgesvd line 40
/packages/7x/petsc/3.11.1/petsc-3.11.1/src/ksp/ksp/impls/gmres/gmreig.c
[0]PETSC ERROR: [0] KSPComputeExtremeSingularValues_GMRES line 22
[0]PETSC ERROR: [0] KSPComputeExtremeSingularValues line 59
/packages/7x/petsc/3.11.1/petsc-3.11.1/src/ksp/ksp/interface/itfunc.c
[0]PETSC ERROR: [0] KSPMonitorSingularValue line 130
/packages/7x/petsc/3.11.1/petsc-3.11.1/src/ksp/ksp/interface/iterativ.c
[0]PETSC ERROR: [0] KSPMonitor line 1765
[0]PETSC ERROR: [0] KSPGMRESCycle line 122
/packages/7x/petsc/3.11.1/petsc-3.11.1/src/ksp/ksp/impls/gmres/gmres.c
[0]PETSC ERROR: [0] KSPSolve_GMRES line 225
[0]PETSC ERROR: [0] KSPSolve line 678
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Signal received
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for
trouble shooting.
[0]PETSC ERROR: Petsc Release Version 3.11.1, Apr, 12, 2019
[0]PETSC ERROR: ./a.out on a linux-gnu-c-debug named cg17-9.agave.rc.asu.edu
by pbaikadi Thu Oct 22 12:07:11 2020
[0]PETSC ERROR: Configure options
[0]PETSC ERROR: #1 User provided function() line 0 in  unknown file
MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
with errorcode 59.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
Is the error because the A matrix is singular (causing the max/min to be
undefined)? Please let me know.
Thank you,
Sincerely,
Pranay.
ᐧ
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20201022/8767c75f/attachment.html>
