[petsc-users] MatOrdering for rectangular matrix
Thu Oct 22 04:55:15 CDT 2020
On Thu, Oct 22, 2020 at 4:24 AM Marcel Huysegoms <m.huysegoms at fz-juelich.de>
wrote:
> Hi all,
> I'm currently implementing a Gauss-Newton approach for minimizing a
> non-linear cost function using PETSc4py.
> The (rectangular) linear systems I am trying to solve have dimensions of
> about (5N, N), where N is in the range of several hundred millions.
> Due to its size and because it's an over-determined system, I use LSQR
> in conjunction with a preconditioner (which operates on A^T x A, e.g.
> BJacobi).
> Depending on the ordering of the unknowns the algorithm only converges
> for special cases. When I use a direct LR solver (as preconditioner) it
> consistently converges, but consumes too much memory. I have read in the
> manual that the LR solver internally also applies a matrix reordering
> beforehand.
> My question would be:
> How can I improve the ordering of the unknowns for a rectangular matrix
> (in order to converge also with iterative preconditioners)? If I use
> MatGetOrdering(), it only works for square matrices. Is there a way to
> achieve this from within PETSc4py?
> ParMETIS seems to be a promising framework for that task. Is it possible
> to apply its reordering algorithm to a rectangular PETSc-matrix?
> I would be thankful for every bit of advice that might help.
We do not have any rectangular reordering algorithms. I think your first
step is to
find something in the literature that you think will work.
     Matt
> Best regards,
> Marcel
> Forschungszentrum Juelich GmbH
> 52425 Juelich
> Sitz der Gesellschaft: Juelich
> Eingetragen im Handelsregister des Amtsgerichts Dueren Nr. HR B 3498
> Vorsitzender des Aufsichtsrats: MinDir Volker Rieke
> Geschaeftsfuehrung: Prof. Dr.-Ing. Wolfgang Marquardt (Vorsitzender),
> Karsten Beneke (stellv. Vorsitzender), Prof. Dr.-Ing. Harald Bolt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20201022/f39b2c65/attachment.html>
