[petsc-users] Eisenstat-Walker method with GPU assembled matrices
Barry Smith
bsmith at petsc.dev
Thu Oct 15 16:32:11 CDT 2020
We still have the assumption the AIJ matrix always has a copy on the GPU. How did you fill up the matrix on the GPU while not having its copy on the CPU?
Barry
When we remove this assumption we have to add a bunch more code for CPU only things to make sure they properly get the data from the GPU.
> On Oct 15, 2020, at 4:16 AM, Héctor Barreiro Cabrera <hecbarcab at gmail.com> wrote:
> Hello fellow PETSc users,
> Following up my previous email <https://lists.mcs.anl.gov/pipermail/petsc-users/2020-September/042511.html>, I managed to feed the entry data to a SeqAICUSPARSE matrix through a CUDA kernel using the new MatCUSPARSEGetDeviceMatWrite function (thanks Barry Smith and Mark Adams!). However, I am now facing problems when trying to use this matrix within a SNES solver with the Eisenstat-Walker method enabled.
> According to PETSc's error log, the preconditioner is failing to invert the matrix diagonal. Specifically it says that:
> [0]PETSC ERROR: Arguments are incompatible
> [0]PETSC ERROR: Zero diagonal on row 0
> [0]PETSC ERROR: Configure options PETSC_ARCH=win64_vs2019_release --with-cc="win32fe cl" --with-cxx="win32fe cl" --with-clanguage=C++ --with-fc=0 --with-mpi=0 --with-cuda=1 --with-cudac="win32fe nvcc" --with-cuda-dir=~/cuda --download-f2cblaslapack=1 --with-precision=single --with-64-bit-indices=0 --with-single-library=1 --with-endian=little --with-debugging=0 --with-x=0 --with-windows-graphics=0 --with-shared-libraries=1 --CUDAOPTFLAGS=-O2
> The stack trace leads to the diagonal inversion routine:
> [0]PETSC ERROR: #1 MatInvertDiagonal_SeqAIJ() line 1913 in C:\cygwin64\home\HBARRE~1\PETSC-~1\src\mat\impls\aij\seq\aij.c
> [0]PETSC ERROR: #2 MatSOR_SeqAIJ() line 1944 in C:\cygwin64\home\HBARRE~1\PETSC-~1\src\mat\impls\aij\seq\aij.c
> [0]PETSC ERROR: #3 MatSOR() line 4005 in C:\cygwin64\home\HBARRE~1\PETSC-~1\src\mat\INTERF~1\matrix.c
> [0]PETSC ERROR: #4 PCPreSolve_Eisenstat() line 79 in C:\cygwin64\home\HBARRE~1\PETSC-~1\src\ksp\pc\impls\eisens\eisen.c
> [0]PETSC ERROR: #5 PCPreSolve() line 1549 in C:\cygwin64\home\HBARRE~1\PETSC-~1\src\ksp\pc\INTERF~1\precon.c
> [0]PETSC ERROR: #6 KSPSolve_Private() line 686 in C:\cygwin64\home\HBARRE~1\PETSC-~1\src\ksp\ksp\INTERF~1\itfunc.c
> [0]PETSC ERROR: #7 KSPSolve() line 889 in C:\cygwin64\home\HBARRE~1\PETSC-~1\src\ksp\ksp\INTERF~1\itfunc.c
> [0]PETSC ERROR: #8 SNESSolve_NEWTONLS() line 225 in C:\cygwin64\home\HBARRE~1\PETSC-~1\src\snes\impls\ls\ls.c
> [0]PETSC ERROR: #9 SNESSolve() line 4567 in C:\cygwin64\home\HBARRE~1\PETSC-~1\src\snes\INTERF~1\snes.c
> I am 100% positive that the diagonal does not contain a zero entry, so my suspicions are either that this operation is not supported on the GPU at all (MatInvertDiagonal_SeqAIJ seems to access host-side memory) or that I am missing some setting to make this work on the GPU. Is this correct?
> Thanks!
> Cheers,
> Héctor
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20201015/3b4362e2/attachment.html>
