[petsc-users] Eisenstat-Walker method with GPU assembled matrices
Héctor Barreiro Cabrera
hecbarcab at gmail.com
Thu Oct 15 04:16:46 CDT 2020
Hello fellow PETSc users,
Following up my previous email
<https://lists.mcs.anl.gov/pipermail/petsc-users/2020-September/042511.html>,
I managed to feed the entry data to a SeqAICUSPARSE matrix through a CUDA
kernel using the new MatCUSPARSEGetDeviceMatWrite function (thanks Barry
Smith and Mark Adams!). However, I am now facing problems when trying to
use this matrix within a SNES solver with the Eisenstat-Walker method
enabled.
According to PETSc's error log, the preconditioner is failing to invert the
matrix diagonal. Specifically it says that:
[0]PETSC ERROR: Arguments are incompatible
[0]PETSC ERROR: Zero diagonal on row 0
[0]PETSC ERROR: Configure options PETSC_ARCH=win64_vs2019_release
--with-cc="win32fe cl" --with-cxx="win32fe cl" --with-clanguage=C++
--with-fc=0 --with-mpi=0 --with-cuda=1 --with-cudac="win32fe nvcc"
--with-cuda-dir=~/cuda --download-f2cblaslapack=1 --with-precision=single
--with-64-bit-indices=0 --with-single-library=1 --with-endian=little
--with-debugging=0 --with-x=0 --with-windows-graphics=0
--with-shared-libraries=1 --CUDAOPTFLAGS=-O2
The stack trace leads to the diagonal inversion routine:
[0]PETSC ERROR: #1 MatInvertDiagonal_SeqAIJ() line 1913 in
C:\cygwin64\home\HBARRE~1\PETSC-~1\src\mat\impls\aij\seq\aij.c
[0]PETSC ERROR: #2 MatSOR_SeqAIJ() line 1944 in
[0]PETSC ERROR: #3 MatSOR() line 4005 in
C:\cygwin64\home\HBARRE~1\PETSC-~1\src\mat\INTERF~1\matrix.c
[0]PETSC ERROR: #4 PCPreSolve_Eisenstat() line 79 in
C:\cygwin64\home\HBARRE~1\PETSC-~1\src\ksp\pc\impls\eisens\eisen.c
[0]PETSC ERROR: #5 PCPreSolve() line 1549 in
C:\cygwin64\home\HBARRE~1\PETSC-~1\src\ksp\pc\INTERF~1\precon.c
[0]PETSC ERROR: #6 KSPSolve_Private() line 686 in
C:\cygwin64\home\HBARRE~1\PETSC-~1\src\ksp\ksp\INTERF~1\itfunc.c
[0]PETSC ERROR: #7 KSPSolve() line 889 in
[0]PETSC ERROR: #8 SNESSolve_NEWTONLS() line 225 in
C:\cygwin64\home\HBARRE~1\PETSC-~1\src\snes\impls\ls\ls.c
[0]PETSC ERROR: #9 SNESSolve() line 4567 in
C:\cygwin64\home\HBARRE~1\PETSC-~1\src\snes\INTERF~1\snes.c
I am 100% positive that the diagonal does not contain a zero entry, so my
suspicions are either that this operation is not supported on the GPU at
all (MatInvertDiagonal_SeqAIJ seems to access host-side memory) or that I
am missing some setting to make this work on the GPU. Is this correct?
Thanks!
Cheers,
Héctor
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20201015/9734d29d/attachment.html>
