[petsc-users] About MAT_NEW_NONZERO_LOCATION[]
Thibaut Appel t.appel17 at imperial.ac.uk
Tue Oct 13 07:47:57 CDT 2020
Hi there, just a quick question:
It seems MAT_NEW_NONZERO_LOCATION_ERR set to PETSC_TRUE has kind of the
same purpose as MAT_NEW_NONZERO_LOCATIONS set to PETSC_FALSE, the
difference being if an additional entry is there, the former produces an
error whereas in the latter it is simply ignored.
However the manual states:
'If one wishes to repeatedly assemble matrices that retain the same
nonzero pattern (such as within a nonlinear or time-dependent problem),
the option MatSetOption(MatA,*MAT_NEW_NONZERO_LOCATIONS,PETSC_FALSE*);
should be specified after the first matrix has been fully assembled.
This option ensures that certain data structures and communication
information will be reused (instead of regenerated) during successive
steps, thereby increasing efficiency'
If I only declare:
     CALL MatSetOption(MatA,MAT_NEW_NONZERO_LOCATION_ERR,PETSC_TRUE,ierr)
Would the data structures still be reused in later matrix assemblies?
Or does it rather make sense to use conjointly:
     CALL MatSetOption(MatA,MAT_NEW_NONZERO_LOCATIONS,PETSC_FALSE,ierr)
Thank you,
Thibaut
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20201013/26343721/attachment.html>
