[petsc-users] Ainsworth formula to solve saddle point problems / preconditioner for shell matrices
Olivier Jamond
olivier.jamond at cea.fr
Mon Oct 12 06:10:02 CDT 2020
Hi Barry,
Thanks for this work! I tried this branch with my code and sequential
matrices on a small case: it does work!
Thanks a lot,
Olivier
On 09/10/2020 03:50, Barry Smith wrote:
> Olivier,
> The branch *barry/2020-10-08/invert-block-diagonal-aij* contains
> an example src/mat/tests/ex178.c that shows how to compute inv(CC').
> It works for SeqAIJ matrices.
> Please let us know if it works for you and then I will implement
> the parallel version.
> Barry
>> On Oct 8, 2020, at 3:59 PM, Barry Smith <bsmith at petsc.dev
>> <mailto:bsmith at petsc.dev>> wrote:
>> Olivier
>> I am working on extending the routines now and hopefully push a
>> branch you can try fairly soon.
>> Barry
>>> On Oct 8, 2020, at 3:07 PM, Jed Brown <jed at jedbrown.org
>>> <mailto:jed at jedbrown.org>> wrote:
>>> Olivier Jamond <olivier.jamond at cea.fr
>>> <mailto:olivier.jamond at cea.fr>> writes:
>>>>> Given the structure of C it seems you should just explicitly
>>>>> construct Sp and use GAMG (or other preconditioners, even a direct
>>>>> solver) directly on Sp. Trying to avoid explicitly forming Sp will
>>>>> give you a much slower performing solving for what benefit? If C
>>>>> was just some generic monster than forming Sp might be unrealistic
>>>>> but in your case CCt is is block diagonal with tiny blocks which
>>>>> means (C*Ct)^(-1) is block diagonal with tiny blocks (the blocks
>>>>> are the inverses of the blocks of (C*Ct)).
>>>>> Sp = Ct*C + Qt * S * Q = Ct*C + [I - Ct * (C*Ct)^(-1)*C] S
>>>>> [Ct * (C*Ct)^(-1)*C] will again be block diagonal with slightly
>>>>> larger blocks.
>>>>> You can do D = (C*Ct) with MatMatMult() then write custom code
>>>>> that zips through the diagonal blocks of D inverting all of them
>>>>> to get iD then use MatPtAP applied to C and iD to get Ct *
>>>>> (C*Ct)^(-1)*C then MatShift() to include the I then MatPtAP or
>>>>> MatRAR to get [I - Ct * (C*Ct)^(-1)*C] S [I - Ct * (C*Ct)^(-1)*C]
>>>>> then finally MatAXPY() to get Sp. The complexity of each of the
>>>>> Mat operations is very low because of the absurdly simple
>>>>> structure of C and its descendants. You might even be able to
>>>>> just use MUMPS to give you the explicit inv(C*Ct) without writing
>>>>> custom code to get iD.
>>>> At this time, I didn't manage to compute iD=inv(C*Ct) without using
>>>> dense matrices, what may be a shame because all matrices are sparse
>>>> . Is
>>>> it possible?
>>>> And I get no idea of how to write code to manually zip through the
>>>> diagonal blocks of D to invert them...
>>> You could use MatInvertVariableBlockDiagonal(), which should perhaps
>>> return a Mat instead of a raw array.
>>> If you have constant block sizes, MatInvertBlockDiagonalMat will
>>> return a Mat.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20201012/fd395c29/attachment.html>
