[petsc-users] Convergence Error Debugging with KSP solvers in SNES
Karl Yang
y.juntao at hotmail.com
Sun Oct 11 01:10:37 CDT 2020
Hi, Barray,
Thank you for helping. I've identified the divergence took place at fieldsplit_1_inner.
It is singular for "pressure field" because I used periodic boundary condition. But doesn't ksp solver by default took care of constant null space?
And if it is necessary, could you give me some help on what's the best location to call MatNullSpaceRemove as the ksp solver is hiding after SNES solver and FIELDSPLIT_PC.
Regards
Juntao
On Oct 9 2020, at 2:25 pm, Barry Smith <bsmith at petsc.dev> wrote:
> Before you do any investigation I would run with one SNES solve
> -snes_max_it 1 -snes_view
> It will print out exactly what solver configuration you are using.
> [0]PETSC ERROR: KSPSolve has not converged, reason DIVERGED_DTOL
> [0]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html (https://link.getmailspring.com/link/FB54F843-9802-454D-9332-7D5C41E03F86@getmailspring.com/0?redirect=https%3A%2F%2Fwww.mcs.anl.gov%2Fpetsc%2Fdocumentation%2Ffaq.html&recipient=cGV0c2MtdXNlcnNAbWNzLmFubC5nb3Y%3D) for trouble shooting.
> [0]PETSC ERROR: Petsc Release Version 3.12.5, Mar, 29, 2020
> [0]PETSC ERROR: ./stokeTutorial on a arch-linux2-c-debug named a2aa8f1c96aa by Unknown Fri Oct 9 13:43:28 2020
> [0]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-mpich --download-fblaslapack --with-cuda
> [0]PETSC ERROR: #1 KSPSolve() line 832 in /usr/local/petsc/petsc-3.12.5/src/ksp/ksp/interface/itfunc.c
> [0]PETSC ERROR: #2 PCApply_FieldSplit_Schur() line 1189 in /usr/local/petsc/petsc-3.12.5/src/ksp/pc/impls/fieldsplit/fieldsplit.c
> Ok, one of the inner solvers went crazy and diverged, that is the norm of the residual for that inner solver exploded.
> Base on the line number
> you can look at that file and see which of the inner solvers failed. From the info from -snes_view you will know what the KSP and PC is for that inner solve and the KSP options prefix. With that you can run the failing case with the addition option
> -xxx_ksp_monitor_true_residual
> and watch the inner solve explode.
> This inner solver behaving badly can also explain the need for -ksp_type fgmres. Normally PCFIELDSPLIT is a linear operator and so you can use -ksp_type gmres but there is some issue with the inner solver. Could it possible have a null space, that is be singular? Do you provide your own custom inner solver or just select from the options database? Does -pc_type lu make everything work fine?
> Barry
> > On Oct 9, 2020, at 12:53 AM, Karl Yang <y.juntao at hotmail.com (https://link.getmailspring.com/link/FB54F843-9802-454D-9332-7D5C41E03F86@getmailspring.com/1?redirect=mailto%3Ay.juntao%40hotmail.com&recipient=cGV0c2MtdXNlcnNAbWNzLmFubC5nb3Y%3D)> wrote:
> > Hi, Barry,
> > Thanks for your reply. Yes, I should have used fgmres. But after switching to fgmres I'm still facing the same convergence issue.
> > Seems like the reason is due to DIVERGED_PC_FAILED. But I simply used FD jacobian, and fieldsplitPC. I am a bit lost on whether I made some mistakes somewhere in the FormFunction or I did not setup the solver correctly.
> > ///////code///////
> > SNESSetFunction(snes, r, FormFunctionStatic, this);
> > // SNESSetJacobian(snes, J, J, FormJacobianStatic, this);
> > SNESSetJacobian(snes, J, J, SNESComputeJacobianDefault, this);
> > SNESMonitorSet(snes, MySNESMonitor, NULL, NULL);
> > SNESGetKSP(snes, &ksp);
> > KSPGetPC(ksp, &pc);
> > PCSetType(pc, PCFIELDSPLIT);
> > PCFieldSplitSetDetectSaddlePoint(pc, PETSC_TRUE);
> > PCFieldSplitSetSchurPre(pc, PC_FIELDSPLIT_SCHUR_PRE_SELF, NULL);
> > KSPMonitorSet(ksp, MyKSPMonitor, NULL, 0);
> > KSPSetTolerances(ksp, 1e-8, PETSC_DEFAULT, PETSC_DEFAULT, PETSC_DEFAULT);
> > SNESSetFromOptions(snes);
> > //////end/////////
> > Output from SNES/KSP solver
> > ################# step 1 #################
> > iter = 0, SNES Function norm 0.0430713
> > iteration 0 KSP Residual norm 4.307133784528e-02
> > 0 KSP unpreconditioned resid norm 4.307133784528e-02 true resid norm 4.307133784528e-02 ||r(i)||/||b|| 1.000000000000e+00
> > iteration 1 KSP Residual norm 4.451434065870e-07
> > 1 KSP unpreconditioned resid norm 4.451434065870e-07 true resid norm 4.451434065902e-07 ||r(i)||/||b|| 1.033502623460e-05
> > iteration 2 KSP Residual norm 1.079756105012e-12
> > 2 KSP unpreconditioned resid norm 1.079756105012e-12 true resid norm 1.079754870815e-12 ||r(i)||/||b|| 2.506898844643e-11
> > Linear solve converged due to CONVERGED_RTOL iterations 2
> > iter = 1, SNES Function norm 2.40846e-05
> > iteration 0 KSP Residual norm 2.408462930023e-05
> > 0 KSP unpreconditioned resid norm 2.408462930023e-05 true resid norm 2.408462930023e-05 ||r(i)||/||b|| 1.000000000000e+00
> > iteration 1 KSP Residual norm 1.096958085415e-11
> > 1 KSP unpreconditioned resid norm 1.096958085415e-11 true resid norm 1.096958085425e-11 ||r(i)||/||b|| 4.554598170270e-07
> > iteration 2 KSP Residual norm 5.909523288165e-16
> > 2 KSP unpreconditioned resid norm 5.909523288165e-16 true resid norm 5.909519599233e-16 ||r(i)||/||b|| 2.453647729249e-11
> > iter = 2, SNES Function norm 1.19684e-14
> > ################# step 2 #################
> > iter = 0, SNES Function norm 0.00391662
> > iteration 0 KSP Residual norm 3.916615614134e-03
> > 0 KSP unpreconditioned resid norm 3.916615614134e-03 true resid norm 3.916615614134e-03 ||r(i)||/||b|| 1.000000000000e+00
> > iteration 1 KSP Residual norm 4.068800385009e-08
> > 1 KSP unpreconditioned resid norm 4.068800385009e-08 true resid norm 4.068800384986e-08 ||r(i)||/||b|| 1.038856192653e-05
> > iteration 2 KSP Residual norm 8.427513055511e-14
> > 2 KSP unpreconditioned resid norm 8.427513055511e-14 true resid norm 8.427497502034e-14 ||r(i)||/||b|| 2.151729537007e-11
> > iter = 1, SNES Function norm 1.99152e-07
> > iteration 0 KSP Residual norm 1.991523558528e-07
> > 0 KSP unpreconditioned resid norm 1.991523558528e-07 true resid norm 1.991523558528e-07 ||r(i)||/||b|| 1.000000000000e+00
> > iteration 1 KSP Residual norm 1.413505562549e-13
> > 1 KSP unpreconditioned resid norm 1.413505562549e-13 true resid norm 1.413505562550e-13 ||r(i)||/||b|| 7.097609046588e-07
> > iteration 2 KSP Residual norm 5.165934822520e-18
> > 2 KSP unpreconditioned resid norm 5.165934822520e-18 true resid norm 5.165932973227e-18 ||r(i)||/||b|| 2.593960262787e-11
> > iter = 2, SNES Function norm 1.69561e-16
> > ################# step 3 #################
> > iter = 0, SNES Function norm 0.00035615
> > iteration 0 KSP Residual norm 3.561504844171e-04
> > 0 KSP unpreconditioned resid norm 3.561504844171e-04 true resid norm 3.561504844171e-04 ||r(i)||/||b|| 1.000000000000e+00
> > iteration 1 KSP Residual norm 3.701591890269e-09
> > 1 KSP unpreconditioned resid norm 3.701591890269e-09 true resid norm 3.701591890274e-09 ||r(i)||/||b|| 1.039333667153e-05
> > iteration 2 KSP Residual norm 7.832821034843e-15
> > 2 KSP unpreconditioned resid norm 7.832821034843e-15 true resid norm 7.832856926692e-15 ||r(i)||/||b|| 2.199311041093e-11
> > iter = 1, SNES Function norm 1.64671e-09
> > iteration 0 KSP Residual norm 1.646709543241e-09
> > 0 KSP unpreconditioned resid norm 1.646709543241e-09 true resid norm 1.646709543241e-09 ||r(i)||/||b|| 1.000000000000e+00
> > iteration 1 KSP Residual norm 1.043230469512e-15
> > 1 KSP unpreconditioned resid norm 1.043230469512e-15 true resid norm 1.043230469512e-15 ||r(i)||/||b|| 6.335242749968e-07
> > iteration 1 KSP Residual norm 0.000000000000e+00
> > 1 KSP unpreconditioned resid norm 0.000000000000e+00 true resid norm -nan ||r(i)||/||b|| -nan
> > Linear solve did not converge due to DIVERGED_PC_FAILED iterations 1
> > PC_FAILED due to SUBPC_ERROR
> > More information from -ksp_error_if_not_converged -info
> > [0] KSPConvergedDefault(): Linear solver has converged. Residual norm 3.303168180659e-07 is less than relative tolerance 1.000000000000e-05 times initial right hand side norm 7.795816360977e-02 at iteration 12
> > [0] PCSetUp(): Leaving PC with identical preconditioner since operator is unchanged
> > [0] KSPConvergedDefault(): Linear solver has converged. Residual norm 2.227610512466e+00 is less than relative tolerance 1.000000000000e-05 times initial right hand side norm 5.453050347652e+05 at iteration 12
> > [0] KSPConvergedDefault(): Linear solver is diverging. Initial right hand size norm 9.501675075823e-01, current residual norm 4.894880836662e+04 at iteration 210
> > [0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> > [0]PETSC ERROR:
> > [0]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html (https://link.getmailspring.com/link/FB54F843-9802-454D-9332-7D5C41E03F86@getmailspring.com/2?redirect=https%3A%2F%2Fwww.mcs.anl.gov%2Fpetsc%2Fdocumentation%2Ffaq.html&recipient=cGV0c2MtdXNlcnNAbWNzLmFubC5nb3Y%3D) for trouble shooting.
> > [0]PETSC ERROR: #3 PCApply() line 444 in /usr/local/petsc/petsc-3.12.5/src/ksp/pc/interface/precon.c
> > [0]PETSC ERROR: #4 KSP_PCApply() line 281 in /usr/local/petsc/petsc-3.12.5/include/petsc/private/kspimpl.h
> > [0]PETSC ERROR: #5 KSPFGMRESCycle() line 166 in /usr/local/petsc/petsc-3.12.5/src/ksp/ksp/impls/gmres/fgmres/fgmres.c
> > [0]PETSC ERROR: #6 KSPSolve_FGMRES() line 291 in /usr/local/petsc/petsc-3.12.5/src/ksp/ksp/impls/gmres/fgmres/fgmres.c
> > [0]PETSC ERROR: #7 KSPSolve() line 760 in /usr/local/petsc/petsc-3.12.5/src/ksp/ksp/interface/itfunc.c
> > [0]PETSC ERROR: #8 SNESSolve_NEWTONLS() line 225 in /usr/local/petsc/petsc-3.12.5/src/snes/impls/ls/ls.c
> > [0]PETSC ERROR: #9 SNESSolve() line 4482 in /usr/local/petsc/petsc-3.12.5/src/snes/interface/snes.c
> > [0] PetscCommDuplicate(): Using internal PETSc communicator 1140850688 -2080374783
> > SNES Object: 1 MPI processes
> > type: newtonls
> > maximum iterations=50, maximum function evaluations=10000
> > tolerances: relative=1e-08, absolute=1e-50, solution=1e-08
> > total number of linear solver iterations=2
> > total number of function evaluations=1322
> > norm schedule ALWAYS
> > Jacobian is built using finite differences one column at a time
> > SNESLineSearch Object: 1 MPI processes
> > type: bt
> > interpolation: cubic
> > alpha=1.000000e-04
> > maxstep=1.000000e+08, minlambda=1.000000e-12
> > tolerances: relative=1.000000e-08, absolute=1.000000e-15, lambda=1.000000e-08
> > maximum iterations=40
> > KSP Object: 1 MPI processes
> > type: fgmres
> > restart=30, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
> > happy breakdown tolerance 1e-30
> > maximum iterations=10000, initial guess is zero
> > tolerances: relative=1e-08, absolute=1e-50, divergence=10000.
> > right preconditioning
> > using UNPRECONDITIONED norm type for convergence test
> > PC Object: 1 MPI processes
> > type: fieldsplit
> > FieldSplit with Schur preconditioner, blocksize = 1, factorization FULL
> > Preconditioner for the Schur complement formed from S itself
> > Split info:
> > Split number 0 Defined by IS
> > Split number 1 Defined by IS
> > KSP solver for A00 block
> > KSP Object: (fieldsplit_0_) 1 MPI processes
> > type: gmres
> > tolerances: relative=1e-05, absolute=1e-50, divergence=10000.
> > left preconditioning
> > using PRECONDITIONED norm type for convergence test
> > PC Object: (fieldsplit_0_) 1 MPI processes
> > type: ilu
> > out-of-place factorization
> > 0 levels of fill
> > tolerance for zero pivot 2.22045e-14
> > matrix ordering: natural
> > factor fill ratio given 1., needed 1.
> > Factored matrix follows:
> > Mat Object: 1 MPI processes
> > type: seqaij
> > rows=512, cols=512
> > package used to perform factorization: petsc
> > total: nonzeros=9213, allocated nonzeros=9213
> > total number of mallocs used during MatSetValues calls=0
> > not using I-node routines
> > linear system matrix = precond matrix:
> > type: seqaij
> > rows=512, cols=512
> > KSP solver for S = A11 - A10 inv(A00) A01
> > KSP Object: (fieldsplit_1_) 1 MPI processes
> > type: gmres
> > PC Object: (fieldsplit_1_) 1 MPI processes
> > type: none
> > Mat Object: (fieldsplit_1_) 1 MPI processes
> > type: schurcomplement
> > rows=147, cols=147
> > Schur complement A11 - A10 inv(A00) A01
> > A11
> > type: seqaij
> > rows=147, cols=147
> > total: nonzeros=147, allocated nonzeros=147
> > A10
> > type: seqaij
> > rows=147, cols=512
> > total: nonzeros=2560, allocated nonzeros=2560
> > using I-node routines: found 87 nodes, limit used is 5
> > KSP of A00
> > type: gmres
> > type: ilu
> > 0 levels of fill
> > type: seqaij
> > rows=512, cols=512
> > type: seqaij
> > rows=512, cols=512
> > A01
> > type: seqaij
> > rows=512, cols=147
> > total: nonzeros=2562, allocated nonzeros=2562
> > type: seqaij
> > rows=659, cols=659
> > total: nonzeros=14482, allocated nonzeros=27543
> > total number of mallocs used during MatSetValues calls=1309
> > On Oct 9 2020, at 2:17 am, Barry Smith <bsmith at petsc.dev (https://link.getmailspring.com/link/FB54F843-9802-454D-9332-7D5C41E03F86@getmailspring.com/3?redirect=mailto%3Absmith%40petsc.dev&recipient=cGV0c2MtdXNlcnNAbWNzLmFubC5nb3Y%3D)> wrote:
> > > When you get a huge change at restart this means something is seriously wrong with either the linear operator or the linear preconditioner.
> > > How are you doing the matrix vector product? Note both the operator and preconditioner must be linear operators for GMRES.
> > > FGMRES allows the preconditioner to be nonlinear. You can try
> > > -ksp_type fgmres -ksp_monitor_true_residual
> > > Barry
> > > > On Oct 8, 2020, at 2:43 AM, Yang Juntao <Y.Juntao at hotmail.com (https://link.getmailspring.com/link/FB54F843-9802-454D-9332-7D5C41E03F86@getmailspring.com/4?redirect=https%3A%2F%2Flink.getmailspring.com%2Flink%2FAA5B8AA2-FFAB-403A-A231-10CE902ACB44%40getmailspring.com%2F0%3Fredirect%3Dmailto%253AY.Juntao%2540hotmail.com%26recipient%3DYnNtaXRoQHBldHNjLmRldg%253D%253D&recipient=cGV0c2MtdXNlcnNAbWNzLmFubC5nb3Y%3D)> wrote:
> > > > Hello,
> > > > I’m working on a nonlinear solver with SNES with handcoded jacobian and function. Each linear solver is solved with KSP solver.
> > > > But sometimes I got issues with ksp solver convergence. I tried with finite difference approximated jacobian, but get the same error.
> > > > From the iterations, the convergence seems ok at the beginning but suddenly diverged in the last iteration.
> > > > Hope anyone with experience on ksp solvers could direct me to a direction I can debug the problem.
> > > > iter = 0, SNES Function norm 2.94934e-06
> > > > iteration 0 KSP Residual norm 1.094600281831e-06
> > > > iteration 1 KSP Residual norm 1.264284474186e-08
> > > > iteration 2 KSP Residual norm 6.593269221816e-09
> > > > iteration 3 KSP Residual norm 1.689570779457e-09
> > > > iteration 4 KSP Residual norm 1.040661505932e-09
> > > > iteration 5 KSP Residual norm 5.422761817348e-10
> > > > iteration 6 KSP Residual norm 2.492867371369e-10
> > > > iteration 7 KSP Residual norm 8.261522376775e-11
> > > > iteration 8 KSP Residual norm 4.246401544245e-11
> > > > iteration 9 KSP Residual norm 2.514366787388e-11
> > > > iteration 10 KSP Residual norm 1.982940267051e-11
> > > > iteration 11 KSP Residual norm 1.586470414676e-11
> > > > iteration 12 KSP Residual norm 9.866392216207e-12
> > > > iteration 13 KSP Residual norm 4.951342176999e-12
> > > > iteration 14 KSP Residual norm 2.418292660318e-12
> > > > iteration 15 KSP Residual norm 1.747418526086e-12
> > > > iteration 16 KSP Residual norm 1.094150535809e-12
> > > > iteration 17 KSP Residual norm 4.464287492066e-13
> > > > iteration 18 KSP Residual norm 3.530090494462e-13
> > > > iteration 19 KSP Residual norm 2.825698091454e-13
> > > > iteration 20 KSP Residual norm 1.950568425807e-13
> > > > iteration 21 KSP Residual norm 1.227898091813e-13
> > > > iteration 22 KSP Residual norm 5.411106347374e-14
> > > > iteration 23 KSP Residual norm 4.511115848564e-14
> > > > iteration 24 KSP Residual norm 4.063546606691e-14
> > > > iteration 25 KSP Residual norm 3.677694771949e-14
> > > > iteration 26 KSP Residual norm 3.459244943466e-14
> > > > iteration 27 KSP Residual norm 3.263954971093e-14
> > > > iteration 28 KSP Residual norm 3.087344619079e-14
> > > > iteration 29 KSP Residual norm 2.809426925625e-14
> > > > iteration 30 KSP Residual norm 4.366149884754e-01
> > > > Linear solve did not converge due to DIVERGED_DTOL iterations 30
> > > > type: newtonls
> > > > SNES has not been set up so information may be incomplete
> > > > total number of linear solver iterations=0
> > > > total number of function evaluations=0
> > > > type: bt
> > > > alpha=1.000000e-04
> > > > type: gmres
> > > > using DEFAULT norm type for convergence test
> > > > type: fieldsplit
> > > > PC has not been set up so information may be incomplete
> > > > FieldSplit with Schur preconditioner, factorization FULL
> > > > Split info:
> > > > not yet available
> > > > not yet available
> > > > type: seqaij
> > > > rows=659, cols=659
> > > > total: nonzeros=659, allocated nonzeros=7908
> > > > Regards
> > > > Juntao
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20201011/8c600e01/attachment-0001.html>
