[petsc-users] compiling PETSc using c++ compiler
    Lisandro Dalcin
    dalcinl at gmail.com
    Wed Oct  7 04:26:25 CDT 2020
On Wed, 7 Oct 2020 at 02:45, Sam Guo <sam.guo at cd-adapco.com> wrote:
>    I want to experiment c++ compiler to see if I can compile real and
> complex versions to different symbols (I've created another thread for this
> topic.) but it seems c++ compiler does not help and I still get same
> symbols.
Indeed, that is not going to make it. Or you have to change the definition
of PETSC_EXTERN, such that it does not use `extern "C"`.  Even with that,
you may have trouble with EXTERN_C_BEGIN/END macros.
Lisandro Dalcin
Senior Research Scientist
Extreme Computing Research Center (ECRC)
King Abdullah University of Science and Technology (KAUST)
http://ecrc.kaust.edu.sa/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20201007/b3551c5c/attachment.html>
