[petsc-users] compiling PETSc using c++ compiler
Satish Balay
balay at mcs.anl.gov
Tue Oct 6 17:35:21 CDT 2020
And BTW: --with-clanguage=cxx is not needed for using PETSc from
c++. It primarily exists for debugging purposes [or some corner cases
where C build of PETSc does not work from c++ code]
Satish
On Tue, 6 Oct 2020, Satish Balay via petsc-users wrote:
> Can you send the complete logs for this build [configure.log, make.log]?
> Satish
> On Tue, 6 Oct 2020, Sam Guo wrote:
> > Dear PETSc dev team,
> > When I compile PETSc using
> > --with-cc=gcc --with-cxx=g++ --with-clanguage=cxx,
> > I got following error:
> > ../../../petsc/src/sys/objects/pinit.c: In function ‘PetscInitialize’:
> > ../../../petsc/src/sys/objects/pinit.c:913:21: error: expected declaration
> > specifiers or ‘...’ before numeric constant
> > 913 | PetscComplex ic(0.0,1.0);
> > ../../../petsc/src/sys/objects/pinit.c:913:25: error: expected declaration
> > ../../../petsc/src/sys/objects/pinit.c:914:15: error: ‘ic’ undeclared
> > (first use in this function)
> > 914 | PETSC_i = ic;
> > ../../../petsc/src/sys/objects/pinit.c:914:15: note: each undeclared
> > identifier is reported only once for each function it appears in
> > Thanks,
> > Sam
