[petsc-users] DMPlexMatSetClosure for non connected points in DM
Tue Oct 6 14:46:57 CDT 2020
On Fri, Oct 2, 2020 at 7:16 PM Ashish Patel <ashish.patel at onscale.com>
wrote:
> Dear PETSc users,
> I am trying to assemble a matrix for a finite element problem where the
> degree of freedom (dof) on a surface is constrained via a reference node
> which also exists in the DM but is not connected  with any other point in
> the mesh. To apply the constraint I want to be able to set matrix values in
> the rows belonging to dofs of reference nodes and columns belonging to dofs
> of surface nodes and vice versa. But since the two points are not connected
> topologically I cannot just use DMPlexMatSetClosure to do that. I am
> currently trying to use DMPlexAddConeSize on all the constrained surface
> points followed by a call to DMPlexInsertCone wherein I add the reference
> node to the cone of surface point before setting up the PetscSection. Is
> this the right approach?
No. You are changing the topology, which is not what you want I think. I
think you just want to associate extra dof with the face. You can
do this by just altering the PetscSection you use. Do you create the
Section yourself now?
    Matt
> I am currently getting following message
> New nonzero at (8952,28311) caused a malloc
> Use MatSetOption(A, MAT_NEW_NONZERO_ALLOCATION_ERR, PETSC_FALSE) to turn
> off this check
> I could set the suggested option to get rid of the error but was wondering
> if I am missing something.
> Thanks
> Ashish
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20201006/c535f967/attachment.html>
