[petsc-users] Visualizing a 3D parallel DMPLEX mesh
Matthew Knepley
knepley at gmail.com
Sat Oct 3 21:19:09 CDT 2020
On Sat, Oct 3, 2020 at 8:36 PM Swarnava Ghosh <swarnava89 at gmail.com> wrote:
> Hi Petsc users,
> I have a 3D distributed DMPLEX mesh. I would like to visualize the mesh.
> Specifically, I want to see domain ownership of every MPI rank, i.e. each
> rank with a different color. . Would you please suggest the best way to do
> this?
I do it this way. I use DMViewFromOptions(dm, NULL, "-dm_view") in my code.
Then I run it
./my_prog -dm_view hdf5:mesh.h5 -dm_partition_view
${PETSC_DIR}/lib/petsc/bin/petsc_gen_xdmf.py mesh.h5
which creates mesh.h5 and mesh.xmf which can be loaded in Paraview. There
is a "rank" field there that you can visualize over the mesh.
Matt
> Sincerely,
> SG
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20201003/ca7d4b65/attachment.html>
