[petsc-users] Debug build fails
Sat Oct 3 10:34:53 CDT 2020
Can use 'git status' to figure out what files are not in the repo.
And a 'git clean -f -d -x' will delete everything except for the files in the repo [so use with care].
Satish
On Sat, 3 Oct 2020, Matthew Knepley wrote:
> On Sat, Oct 3, 2020 at 11:11 AM Zane Charles Jakobs <
> Zane.Jakobs at colorado.edu> wrote:
> > Hi PETSc devs,
> > I just pulled the latest version of PETSc on master, and while my
> > optimized build works fine, my debug build fails with the message
> > make[1]: *** No rule to make target 'src/sys/logging/examples/makefile'.
> > Stop.
> > make: *** [GNUmakefile:17: src/sys/logging/examples/makefile] Error 2
> > Doing
> > ls src/sys/logging/examples
> Remove this directory. It is not in the repository, and its presence is
> confusing the automatic detection for the build.
>   Thanks,
>      Matt
> > shows a file named `index.html` and a directory named `tutorials`, but no
> > makefile. My configure line is
> > ./configure PETSC_ARCH=arch-linux-c-debug --with-cc=clang
> > --with-cxx=clang++ COPTFLAGS="-O3 -march=native -mtune=native -fPIC"
> > CXXOPTFLAGS="-O3 -march=native -mtune=native -fPIC" FOPTFLAGS="-O3
> > -march=native -mtune=native -fPIC" --with-avx2=1 --download-mpich
> > --download-hypre --download-scalapack --download-mumps --with-debugging=yes
> > --with-blaslapack-dir=/opt/intel/mkl --download-zlib --download-libpng
> > --download-giflib --download-libjpeg --download-slepc --download-eigen
> > To reiterate, doing the exact same configure, but changing
> > '-with-debugging=yes' to '-with-debugging=no' (and changing the PETSC_ARCH
> > name to 'arch-linux-c-debug') and then building the non-debugging version
> > of PETSc works as normal. Any ideas what could be going on?
> > Thanks!
> > -Zane Jakobs
